5.5 gurus step in please
Old Sep 11, 2008 | 09:12 PM
BLACKKILA.GTR's Avatar
ok lemme start off by saying i might go stick but later on down the line..lol
ok i think im losing power but im not too sure where,
let me start out with mods
headers-ss autochrome
undercrank pulley
true cold air intake
custom exaust with cattman axel back-still have resonator and cat
tranny cooler
now ive been beatin by a stock 5.5 gen and a altima ser not too sure if it could be wieght issues or wat..lol
at the track i barely broke 15's best time was 15.83
on the dyno i only made 205 hp....
any imput my fellow auto 5.5 doods?
Old Sep 11, 2008 | 09:29 PM
skidz88's Avatar
It's your headers. The headers you have are basically stock manifolds, just polished up. They may even be worse for the car than the stock headers were.
Old Sep 11, 2008 | 09:48 PM
Feldman's Avatar
205 hp is a little low but about what you should be putting down. what kind of tires are you running?
Old Sep 11, 2008 | 10:42 PM
jasonmax's Avatar
automatic? hum...
Old Sep 11, 2008 | 10:45 PM
Scottwax's Avatar
That's Mr. Detail to you
What is your oil comsumption like? When is the last time the plugs were changed? Have you tried resetting the ECU?
Old Sep 11, 2008 | 11:30 PM
jasonmax's Avatar
time for a new MAF
Old Sep 12, 2008 | 03:10 AM
how can i reset the ecu...?
i personally think the headers are garbage myself but it was a quik fix from my stock ones.. anyone else think it could be the headers??
maf?? im not too sure about that one....
as for tires ill take a look in the morn and put that on here
Old Sep 12, 2008 | 05:48 AM
mist max2000's Avatar
from all the reading ive done.. those headers yeild about no change in HP.. ..and are about equivalent to the stillen ones.. if u want hp.. cattman or hottshot(no longer in buisness) ...
Old Sep 12, 2008 | 06:27 AM
skidz88's Avatar
Just curious, but what do tires have to do with dyno HP numbers? lol
The weight of rims/tires can affect the outcome, but only by a bit. I'm positive it's the headers that are making you see low numbers. Get some Cattmans and a tune then report back.
Old Sep 12, 2008 | 07:33 AM
User 12822's Avatar
undercrank pulley
tranny cooler
wow lol your slower than my auto 5.0 gen
you should try fuel injector cleaner too
Old Sep 12, 2008 | 07:57 AM
amomaxima's Avatar
MAF cleaner (dont jump into replacement yet)
spark plugs
93 octane if your not running it now
Redline Injector cleaner
Do you have the stock cat or any cat?
If so check it and make sure it is still flowing, if it isnt probably, alot to do with low number in output
Tires have almost no effect on HP, they will lower your numbers if they are too big for the car. The amount of effort it will take to spin big wheels hurts your output power band.
Old Sep 12, 2008 | 08:02 AM
Czerkas's Avatar
Thats awesome .. Im going to start using that .. ya its a 5.0 *cough* gen *cough*
Old Sep 12, 2008 | 08:44 AM
CMax03's Avatar
WHO's NO LONGER IN BUSINESS?
Old Sep 12, 2008 | 08:54 AM
CMax03's Avatar
If You're a 5th Gen with the VQ30dE-K(modded w/ 205 whp), those #'s are about the same as a stock 5.5 Gen, so maybe that 5.5 Gen didn't beat you that bad, you just never caught up after they jumped you out the hole! I got my butt whipped by a SER @ the drag strip. His reaction time beat me, 100 more feet he was mine!
Old Sep 12, 2008 | 08:55 AM
Torgus's Avatar
205 is about what a 5.5 puts down stock unless i'm wrong.
15.85 is horrible. i ran 15 flat with my 19s and a cooler full of beer and ice my 1st time at the track in my 5.5...stock they should run 14.7-14.9...
good luck!
Old Sep 12, 2008 | 09:08 AM
CMax03's Avatar
I 'm sorry! I thought he was a 5.0 gen! 202-208 whp is the window for 5.5 Gen's and the stock 1/4 mile was 14.9-15.3 sec in all the mags that I've read which tested the 5.5 gen (Sport Compact Car)! He's definitely may have a problem with his MAF sensor or cat! Or technique
Old Sep 12, 2008 | 09:13 AM
User 12822's Avatar
LMFAO
Old Sep 12, 2008 | 09:19 AM
Feldman's Avatar
sounds like you aren't getting the power to the ground. What tires are you running?
Old Sep 12, 2008 | 09:35 AM
DrunkieTheBear's Avatar
Turbo'd Saab
whats your A/F? do you have an AFC? I think you need a good tune, ditch those headers and get some better ones. Also any check engine lights for the o2 sensors on the front bank? also check your coilpacks, spark plugs, make sure not misfiring.
Old Sep 12, 2008 | 11:36 AM
car is a5.5 gen with the vq 3.5
my engine light was on for my o2's but then it went away kind wierd.. out here since the elavation is so high the best gas they have is 91
as for cat's i still have the stock cat ima check that about to just buy a highflow cat...
the car was tuned but its wierd the tuning sheet didnt show my torque....
first run cam out with 203.. best run was 205 i dont think he was using all the tuning points on my vafc2 though
dam cattman are expensive...lol
Old Sep 12, 2008 | 12:10 PM
hotshot.. or at least they no longer make headers for our cars... speaking of out of buisness.. greddy just filed for bankruptcy..
Old Sep 12, 2008 | 02:02 PM
Torgus's Avatar
get some cattmans and do a tune and you should be around 225-230. they are expensive but it's that or a turbo for your next power adder.
As for your 1/4 time perhaps you don't launch well what was your 60? got a slip for us to see?
Old Sep 12, 2008 | 05:38 PM
danger300z's Avatar
no way??
Old Sep 12, 2008 | 07:00 PM
knight_yyz's Avatar
Toolie
That's a low estimate. Should be closer to the 240 range.
Old Sep 12, 2008 | 07:28 PM
Scottwax's Avatar
What is your trap speed? ET can be affected by wheelspin, bogging, etc but the trap speed is a good indicator of the power your car is making. If you are under 93-94 with an automatic that you are probably missing some power that you should have.
Apr 16, 2020 05:15 AM
gigabyte
Jan 6, 2017 06:05 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
