View Poll Results: Engine Pinging
Yes, still happening
54.84%
Yes, but has been fixed
9.68%
No, lucky I never had it.
35.48%
Voters: 31. You may not vote on this poll
Poll- Engine pinging?
Old Sep 15, 2008 | 12:11 PM
gotendbz1's Avatar
Engine pinging?
Just want to know how many people have had the engine pinging issue and how many people have had it resolved. I just began having this issue and want to see how widespread it was and maybe find a fix for the problem.
Old Sep 15, 2008 | 12:32 PM
vinco's Avatar
I've heard my engine ping only one time, and I really had no explanation for it at that time (2KSE, 5MT). I was entering the freeway pretty heavy on the gas in 2nd gear, and it pinged on me until I let up on the gas some. It hasn't done it since - even during my track day at Hallett. I always run premium, and my plugs are new-ish. Maybe I got a tank of premium that was "light on the octane."
Old Sep 15, 2008 | 03:23 PM
knight_yyz's Avatar
Toolie
NWP spacers seem to help. Not sure if it's because the oem gasket leaks a little bit causing a lean condition, but it helped on my car and another friend of mine as well.
Old Sep 15, 2008 | 03:42 PM
gotendbz1's Avatar
only problem is spacer are expensive, did you have pinging and the spacers resolved it?
Old Sep 15, 2008 | 03:54 PM
knight_yyz's Avatar
Toolie
yes, but I'm not saying the spacers solved it. It's possible the oem gaskets were leaking. With the NWP's you use an RTV sealant so it guarantees that there will be no leak.
Old Sep 18, 2008 | 09:19 PM
gotendbz1's Avatar
tryign to resolve the my pinging issue and replaced plugs today with 1 step colder 1's and it helped a little, also i have oil in rear spark plug tube from vavle cover im guessing. any idea for getting rid of the pinging?
Old Sep 24, 2008 | 10:06 PM
flatcat19's Avatar
Ummm...fix the leak going into your spark plug. Let me guess...#5? A fouled-out plug is one that is being a slacker, which would cause pinging. 5 1/2 plugs firing would definately be a cause of that. Of course, you're running super-so what else could it be? Spark or fuel. Cause and effect. And while you have that intake off fixing the leak in the back cover...NWP Spacers!!! Church!
Old Sep 25, 2008 | 01:59 AM
4thgenmaxboy's Avatar
Mine started pinging today. It doesn't happen all that often. I think its the cheap *** gas that we keep buying today that contributes to alot of the pinging in our motors. Who knows what is in the gas where purchasing for our vehicles. I've never seen an CEL on my Max, but my max has less than 50k miles on my car.
Old Sep 25, 2008 | 08:25 AM
gotendbz1's Avatar
when did misfire cause pinging? also the oil leaking into there is just a hassell with checkign oil level. i thought about spacers.
Old Sep 25, 2008 | 09:28 AM
streetracero1's Avatar
i have only had that problem after moron at the gas pump gave me regular instead of super.
James92SE
142
Jan 2, 2024 09:23 AM
fastcarny
Oct 6, 2015 10:42 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
