Quick Alternator wiring question
Old Sep 17, 2008 | 06:33 AM
Mynameismcgyver's Avatar
I am installing a 200A alternator in the next few days for my audio setup. Looking to upgrade the wire to 4 or 0 gauge and run that directly to the battery. If I bypass the original wiring, am I going to cause any problems?
Or should I just hook up the extra wire in conjunction with the original which will let the current pick which wire it would use.
Old Sep 17, 2008 | 06:52 AM
Wiking's Avatar
Originally Posted by Mynameismcgyver
... let the current pick which wire it would use.
Old wiring may stay or go, no problem. Original has a 120A fuse (good?) ... bad, oxidized, melting fuse may become a hazard itself...
The only problems I fear, is worn/broken wire insulation = shorting. With thick nonfused wires this may pose a fire hazard. Use lots of tie wraps. Try to make it also collision proof...
I have nonfused thumb thick wires to my H4 lamps - enough light is on top of all, fires hazard is below it. This is an oldie problem - now solved http://www.cardomain.com/ride/748507/11
Balkins
Feb 1, 2016 12:45 AM
soloist3
29
Sep 1, 2015 03:47 PM
JMag90
Aug 25, 2015 09:17 AM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 13, 2015 04:05 PM
