Vehicle Reliability Survey results
Old Feb 21, 2012 | 10:45 AM
  #41
mkaresh's Avatar
We have updated our reliability stats for the Maxima and I30/I35 (on our redesigned site) to include owner experiences through September 30, 2011.
Repair frequencies, in terms of repair trips per 100 cars per year:
2003: 57, better than average, small sample size
2002: 119, about average
2001: 140, about average
2000: 151, about average
Thank you, once again, to everyone who has been helping. We'll have further updates later this month and in May. With more participants, we could provide more precise information and cover all model years.
To see how competitors compare, and to sign up to help improve this information:
Nissan Maxima reliability ratings and comparisons
Old Jan 7, 2013 | 09:05 AM
  #42
mkaresh's Avatar
We have updated our reliability stats for the Maxima and I30/I35 to include owner experiences through September 30, 2012.
2003: 61, about average
2002: 97, worse than average
2001: 83, better than average
2000: 114, worse than average
We'll have further updates in February and May. The more owners participate, the more precise these stats will be.
To see how competitors compare, and to sign up to help:
Old May 14, 2013 | 06:16 AM
  #43
mkaresh's Avatar
We have updated our reliability stats for the Maxima and I30/I35 to include owner experiences through December 31, 2012.
2003: 57, low
2002: 83, moderate
2001: 67, low
2000: 116, high
The small sample sizes could explain some or even much of the variation among the affected model years.
Thank you, once again, to this forum and everyone who has been helping. We'll have further updates later this month and in August. The more owners participate, the more comprehensive and precise these will be.
Old Aug 5, 2013 | 08:19 AM
  #44
mkaresh's Avatar
We've updated our reliability stats for the Maxima to include owner experiences through March 31, 2013.
2003 Maxima: 52, low
2002 Maxima: 105, moderate
2001 Maxima: 85, low
2000 Maxima: 128, high
We'll have further updates in August and in November.
For the details, including the descriptions of reported repairs, and to sign up to help improve this information:
Old Aug 5, 2013 | 06:43 PM
  #45
noahrexion's Avatar
Great site, I just signed up both my vehicles.
Old Aug 9, 2013 | 05:53 PM
  #46
george__'s Avatar
My Maxima (2002) has needed A LOT OF WORK
Old Aug 9, 2013 | 06:55 PM
  #47
cdoublejj's Avatar
i'm interested in hearing the miles and work on maxima.org members' 5th gens. some people are getting 250+K miles.
Old Aug 9, 2013 | 07:09 PM
  #48
george__'s Avatar
Canadian car with about 199,000 KM with some mods...
So far (that comes to mind)
Rear Right ABS Sensor
Fuel filler neck + gas cap
2 rear O2 sensors
Spark Plugs
Suspension (front/rear)
Sway bar end links (driver/passenger)
Valve covers (front/rear)
evap canister + valve
exhaust (due to leaks)
parking brake
fluid swapping
filters
some switches weren't working so I had to fix it up
DRL (day time running light module)
rear wheel well rust fix
still need to fix up leaking CV Boots (driver/passenger side)
This is my second car and I've owned it less than a year.
I knew the car would require a lot of maintenance but not all at once....
Old Aug 10, 2013 | 06:15 AM
  #49
Norm Peterson's Avatar
Just turned over 115,000 miles on a 20AE model I bought new (2001, so about 12.5 years). All I can remember offhand has been a couple of oxygen sensors, an ABS wheel sensor, a radiator, "volume air flow" (mass air flow?), either two or three alternators (at least one was a short-lived remanufactured unit), and an A/C compressor.
It's only on its third set of tires (which are maybe half worn), and second set of brake pads. Car is not and never has been driven "gently" to extend the lives of those components.
I have had to weld up two or three cracks in the exhaust line. Not too bad for a car that has seen 12 winters of snow/salt and has never been garaged.
All in all, it's been a pretty reliable car.
Norm
Old Aug 13, 2013 | 07:46 AM
  #50
mkaresh's Avatar
2 rear O2 sensors
Spark Plugs
parking brake
fluid swapping
filters
Age + km + winter driving will do it.
Old Nov 8, 2013 | 09:35 AM
  #51
mkaresh's Avatar
We've updated our reliability stats for the Maxima to include owner experiences through June 30, 2013.
2003 Maxima: 40, low
2002 Maxima: 79, low
2001 Maxima: 94, moderate
2000 Maxima: 120, high
We'll have further updates later this month and in February.
To view competitors' scores and descriptions of reported repairs, and to sign up to help:
Old Jan 10, 2014 | 08:38 AM
  #52
mkaresh's Avatar
We've updated our reliability stats for the Maxima to include owner experiences through September 30, 2013.
2003 Maxima: 51, low
2002 Maxima: 84, low
2001 Maxima: 89, moderate
2000 Maxima: 107, moderate
We'll have further updates in February and in May. The more owners participate, the more comprehensive and precise these will be.
Old Jan 10, 2014 | 04:46 PM
  #53
george__'s Avatar
Update for me.
Replaced...
Idler Pulley
Alternator seized...
got the car a new battery
new belts
car now has ~204,500 km
Old Jan 10, 2014 | 05:15 PM
  #54
The_Fixer's Avatar
Ok so here is my stats and options
2nd owner purchased in 2005 with 38,000 +/- miles now has 84,000 miles
Added Options.
NWP spacers,BOP,TL,TB
Franken SRI
Stillen UDP
Stillen F/R STB & R swaybar
SS brakelines,EBC rotors and pads
All Energysuspension Bushings
BC coilovers
Cattman headers and 2 1/2" exhaust fastcat converter.
6th gen valve covers
Stillen ground kit
The Nitty Gritty
Oil changed every 2500
MAF replaced in 2010 w/ecu flash
Plugs changed every year in april
1 front coil replaced from failure
Pads,Rotors and fluid replaced yearly
Alternator and tension pulley replaced oct 2012 failed and i snapped the tensioner adjust nut.
PS wheel bearing and hub replaced 2012 made noise
Radiator and thermostat replaced 2012 top split on rad so did both.
Need to replace seat front to back motor
Thats all the problems i have had.unlike some people i read the cause and effect of doing upgrades to the car and try to learn from other peoples mistakes.the car has been no problem for me at all.i enjoy owning it and working on it.
Old Jan 10, 2014 | 05:35 PM
  #55
george__'s Avatar
I got a lemon car or this was a car kept in semi storage for a long time (like father could no longer drive due to age) and then someone got a hold of it (the kids) and not knowing a lot about cars or not caring they sold it for dirt cheap..
Old Apr 7, 2014 | 09:33 AM
  #56
mkaresh's Avatar
We've updated our reliability stats for the Maxima to include owner experiences through December 31, 2013.
2003 Maxima: 74, moderate
2002 Maxima: 83, moderate
2000 Maxima: 101, moderate
We'll have further updates in May and in August. The more owners participate, the more comprehensive and precise these will be.
To see the repairs behind these stats, and to sign up to help improve this information:
Old May 28, 2014 | 09:28 PM
  #57
juliusR's Avatar
If you aren't sure of what car you are going to buy, you can look at Consumer Reports to help you decide. It will show you a list of best and worst model of cars every year, including the rank of vehicles according to dependability. Here is the source: Consumer Reports Best Cars List.
Old May 29, 2014 | 10:40 PM
  #58
maxiiiboy's Avatar
Can you define you Repair Frequency better. Is it based on:
- Repair frequency for the lifetime of the car?
- For the last year?
- For the last reporting period?
It's hard trust these numbers when it's unclear what they mean ....
Old May 29, 2014 | 11:48 PM
  #59
Donkeypunch's Avatar
Mine's a 2000, 14 years old.
Other than maintenance replacement parts that need to be changed
just like the 03 I don't see why a 2000 is less reliable.
Does the radiator count? I've replaced that and read it's a common problem.
Also I'm reading that people had to change the struts, motor mounts, a coil as a problem???
Replacing pads and rotors?
Does changing the oil count as a problem too?
Old May 30, 2014 | 05:39 AM
  #60
Struts, pads, and rotors are "wear parts" that you expect to have to be replacing at some point as regular maintenance items.
Motor mounts and coils, not so much. Not that neither of those can't fail, just that they shouldn't "wear out" and need replacement on some predictable schedule.
Norm
Old Jul 13, 2014 | 12:01 PM
  #61
mkaresh's Avatar
We have instructions as to what counts on the survey form. Nearly everything not on a maintenance schedule counts, though a few things we only count for up to 24k miles.
Our reliability stats for the Maxima now include owner experiences through March 31, 2014, making them nearly a year ahead of other sources.
2003 Maxima: 74, low
2002 Maxima: 82, moderate
2000 Maxima: 80, low
Thank you, once again, everyone who has been helping. Next update in August.
For a deeper dive, including the stats for other cars and repair descriptions, and to sign up to help improve this information:
Old Oct 9, 2014 | 09:30 AM
  #62
mkaresh's Avatar
We've updated our reliability stats for the Maxima to include owner experiences through June 30, 2014 (making them about 14 months ahead of some others).
2003 Maxima: 87, moderate
2002 Maxima: 90, moderate
2001 Maxima: 119, high
2000 Maxima: 79, low
Next updates in November and in February. The more owners participate, the more comprehensive and precise these will be.
For repair descriptions, the stats of other cars, and to sign up to help improve this information:
Old Dec 30, 2014 | 10:44 AM
  #63
mkaresh's Avatar
We've updated our reliability stats for the Maxima to include owner experiences through September 30, 2014.
2003 Maxima: 68, low
2002 Maxima: 76, low
2001 Maxima: 95, moderate
2000 Maxima: 71, low
Additional participants always helpful (especially if you see "small sample size" next to the year, or no stat at all).
To view the repairs behind these numbers, check the stats for other cars, and sign up to help improve this information (next update in February):
Old Apr 15, 2015 | 06:29 AM
  #64
mkaresh's Avatar
We've updated our reliability stats for the Maxima to include owner experiences through the end of 2014.
2003 Maxima: 62, low
2002 Maxima: 65, low
2001 Maxima: 121, high
For the details, including how competitors compare, and to sign up to help improve this information:
Old Apr 15, 2015 | 03:39 PM
  #65
tnj9's Avatar
My 03 has held up well besides damage I caused when I was younger and had repaired. At 165k now and wiser.
Old Apr 15, 2015 | 05:00 PM
  #66
2kMaxim's Avatar
Maximas are misunderstood. I think they are an amazingly reliable car if you are the type of person that doesn't have to go to a shop just because you threw a code. A lot of the stuff that has happened with my maxima has been easy stuff to fix if you know what you are doing. On that note, for tuner types i would highly recommend a maxima...for a soccer mom..hellz no.
Old Aug 21, 2015 | 08:09 AM
  #67
mkaresh's Avatar
So, how have these cars been doing lately?
Our reliability stats for the Maxima now include owner experiences through March 31, 2015. (Others are nearly a year behind.)
In terms of repair trips per 100 cars per year ("low" is best):
2003 Maxima: 93, moderate, small sample size
2002 Maxima: 58, low
2001 Maxima: 97, moderate, small sample size
2000 Maxima: 93, moderate
Additional participants always helpful, especially for the years with small sample sizes. Next updates in late August and November.
For repair descriptions, the stats for other cars, and to sign up to help improve this information:
Old Oct 27, 2015 | 11:20 AM
  #68
mkaresh's Avatar
Our reliability stats for the Maxima now cover the year ending June 30, 2015.
Repair trips per 100 cars:
2003 Maxima: 103, moderate, small sample size
2002 Maxima: 96, moderate
2001 Maxima: 110, moderate, small sample size
2000 Maxima: 112, moderate
If a model year's sample size is small, then we especially need more owners involved.
For the descriptions of all reported repairs, results for other models, and to sign up to help improve this information:
Old Jan 28, 2016 | 09:07 AM
  #69
mkaresh's Avatar
We've updated our reliability stats for the Maxima to include owner experiences through September 30, 2015. In terms of repair trips per 100 cars per year:
2003 Maxima: 118, high, small sample size
2002 Maxima: 107, moderate
2001 Maxima: 121, high, small sample size
2000 Maxima: 96, moderate, small sample size
We'll have further updates in February and in May. Additional participants are needed to provide precise stats for all model years.
For the details, including repair descriptions, and to sign up to help improve this information:
Old Mar 28, 2016 | 12:08 PM
  #70
mkaresh's Avatar
We've updated our reliability stats for the Maxima to include owner experiences through the end of 2015, about eight months ahead of other sources. In terms of repair trips per 100 cars per year--lower is better:
2003 Maxima: 144, high, small sample size
2002 Maxima: 92, moderate
2001 Maxima: 86, moderate, small sample size
2000 Maxima: 83, moderate, small sample size
Small sample size? Then we especially need more owners involved for that model year.
For the repairs behind these stats, reliability information on other models, and to sign up to help improve this information:
Old Dec 23, 2016 | 01:36 PM
  #71
mkaresh's Avatar
We've updated our reliability stats for the Maxima to include owner experiences through September 30, 2016. In terms of repair trips per 100 cars per year (lower is better):
2003 Maxima: 148, high, very small sample size
2002 Maxima: 61, low, small sample size
2001 Maxima: 89, moderate, very small sample size
The amount of variation is likely do to the sample sizes.
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Sep 27, 2015 08:37 AM
