Sunroof tilt works but wont open
Old Oct 6, 2008 | 05:09 PM
rosader's Avatar
My sunroof will tilt with the tilt button but does nothing when i slide the open button. it has always worked up until now. What could the problem be?
Old Oct 6, 2008 | 05:26 PM
Feldman's Avatar
The switch is probably the culprit. But to make sure i would see if you are getting power to the motor when the button is pressed. check connections at both ends as well and make sure all connections are tight and clean
Old Oct 6, 2008 | 07:31 PM
choiiiiiiiiiii's Avatar
try holding the button down like your closing it for ten seconds.
Old Oct 6, 2008 | 08:00 PM
Feldman's Avatar
somebody made reference to a reset procedure in scottwax's sun roof post. maybe try searching that... unless holding the button down for 10 seconds is that procedure.
Old Oct 6, 2008 | 08:19 PM
Scottwax's Avatar
That's Mr. Detail to you
Works about 90% of the time so you may have to repeat it. For some reason, if you don't use your sunroof regularly, it only tilts and you have to reset it to open it. I only use mine in the spring and fall so when it cools off or warms up enough to use it, I have to do the reset.
Old Oct 6, 2008 | 08:36 PM
hi-tek22's Avatar
what i did to reset that was UNPLUG my neg battery for about an hour
or you could disconnect the sunroof relay and plug it back in
Old Dec 27, 2008 | 11:25 AM
rroderiques77's Avatar
Demodded and Forgotten
WOW. IT WORKED!!
maxinout93
Oct 27, 2015 01:29 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
BobMax
Aug 15, 2015 12:35 PM
Flores94
Aug 13, 2015 01:17 PM
kenc15
Aug 5, 2015 08:29 AM
