Speedo Problem
Old Oct 7, 2008 | 08:11 PM
SickMaxima's Avatar
Speedo Problem
Hello guys, got a problem. About a year ago my car was broken into and my in-dash navi was stolen. When the scumbags ripped it out they destroyed the wiring harness, i brought it to lynnes nissan in Bloomfield NJ and they replaced it but when i got the car back the speedometer and odometer doesn't work. They are telling me that i brought it in like that and its the speedo gear and its my fault and want to charge me $1600 to fix it. I think when they replaced the wiring harness they blew out the speedo sensor and that why it doesn't work. I want to check it and try replacing the sensor but i dont know where i can get a sensor without going threw nissan. Does anyone have one or know where i can get it?
Old Oct 7, 2008 | 08:22 PM
pmohr's Avatar
No more Maximas...
Year of your car might help, as well as 4AT/5MT/6MT.
When did they lift the 15 post requirement for new threads?
Old Oct 7, 2008 | 08:29 PM
SickMaxima's Avatar
its a 2000 with a 5mt...but im pretty sure that doesnt matter, im pretty sure that the sensor fits both an auto and manual car.
Old Oct 7, 2008 | 08:37 PM
pmohr's Avatar
No more Maximas...
Not according to FAST it doesn't.
Anyway, have you tested your current VSS, or have an error code for it? That would be the first thing to do, rather than just replacing it.
Old Oct 7, 2008 | 08:42 PM
SickMaxima's Avatar
i ran the codes and its only throwing one for an 02 sensor...i brought it to a local shop my friend works at and they hooked it up to a computer and i drove the car around the block and it wasnt picking up a speed...he said its eathier the sensor or the gear, but due to the fact that the wiring harness was replaced there is a better chance of the speedo sensor being blown then it being the gear.
Old Oct 8, 2008 | 09:20 AM
SickMaxima's Avatar
bump!!!
Old Oct 8, 2008 | 06:58 PM
SickMaxima's Avatar
bump for an answer!
Old Oct 8, 2008 | 07:08 PM
pmohr's Avatar
No more Maximas...
bump for an answer!
Well? Also, continuity on the wiring harness?
Old Oct 8, 2008 | 07:13 PM
SickMaxima's Avatar
might be a dumb question but when is the VVS?
Old Oct 8, 2008 | 07:14 PM
pmohr's Avatar
No more Maximas...
When is the VVS?
I'm guessing either, 'what is the VSS' or 'where is the VSS'.
Vehicle Speed Sensor, and on the trans, right above the diff.
Old Oct 8, 2008 | 07:18 PM
SickMaxima's Avatar
thats what i mentioned originally, the speedo sensor in the trans...i have not checked it yet, i am 99% sure eathier thats the problem or the actual gear in the trans. but im goin with the sensor. where can i get another one if that is the problem...and about how much would that cost and can i replace it my-self?
Old Oct 8, 2008 | 07:31 PM
pmohr's Avatar
No more Maximas...
It only takes one bolt and one connector to replace it; whether or not you feel the ability to, that's up to you.
The dealer, or check with auto parts stores. They all have online catalogs now, look it up.
Maybe you should diagnose it before thinking about replacing it?
Old Oct 8, 2008 | 07:36 PM
SickMaxima's Avatar
well i brought the car to a shop and they told me its eathier the sensor or the gear but they wanted to drop the trans to get at it and from what i understand from alittle research you can get at it from the drivers side front wheel well...what ill do is take the sensor off and look to see if the gear is still intact or if the teeth have been striped off which is what a nissan dealership told me happened(but they nvr looked at the gear)...if the gear is fine is there any way to check to see if the sensor is anygood?
Old Oct 8, 2008 | 07:49 PM
pmohr's Avatar
No more Maximas...
Yes. By testing it. As I've been saying. EC-501.
Old Oct 8, 2008 | 07:55 PM
SickMaxima's Avatar
ec-501?
how do i test it?
sry if i am asking stupid questions but i appreciate your help alot
Old Oct 8, 2008 | 07:56 PM
pmohr's Avatar
No more Maximas...
ec-501?
how do i test it?
EC-501 goes through the diagnostics for the sensor.
Old Oct 8, 2008 | 07:58 PM
SickMaxima's Avatar
would that show up on an OBD-2 scanner? because the only codes its showing is for a bad o2 sensor
Old Oct 8, 2008 | 08:04 PM
pmohr's Avatar
No more Maximas...
Would what show up?
Old Oct 8, 2008 | 08:06 PM
SickMaxima's Avatar
ill have to check tomorrow...
Old Oct 8, 2008 | 09:10 PM
SickMaxima's Avatar
sry its late...i ment would it show up on an obd-2 scanner...because when i plug the scanner in it just shows up an a bad o2 sensor in bank 2
Old Oct 8, 2008 | 09:12 PM
pmohr's Avatar
No more Maximas...
P0500 should show up, yes. Of course, that doesn't necessarily mean that it will. Would also be a good idea to check continuity all the way up to the cluster itself.
Old Oct 9, 2008 | 05:32 PM
SickMaxima's Avatar
i am gonna try checking the wire all the way back up to the cluster probably next weekend...with school n work i have no time...but ill check that out before i go buy a new sensor
Old Oct 9, 2008 | 05:58 PM
Max_5gen's Avatar
You do have a FSM for your car, don't you? That's what pmohr is referring to, down to section and page number.
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
