how to tell if fuel injector/s bad?
Old Oct 14, 2008 | 08:36 AM
miksen's Avatar
FU, FU, FU, You're Cool..
I have been getting lean codes on and off. Ran injector cleaner…..BUT,
I notice a loud clicking sound when initially giving gas. Sounds like a loud tap almost.
To be clear I hear a slight clicking when idle. If I lay my foot on gas ever so slightly (pedal barley moves) RMPS have not yet changed and I hear the clicking or tapping sound get noticibly louder but levels out....only gets so loud. Analogy…sounds like someone hitting a single key on a typewriter over and over.
I have headers so once I getting going it’s nearly impossible to hear it from inside the cabin. I doubt it is any type of a mechanical failure (engine…rods/valves, ect…) or I’m sure it would get increasingly loud as I put load on the engine and the RPMS increase.
Questions:
How to validate an injector is bad?
Is it difficult to replace one?
Should I just replace all of them on that rail?
Heck should I just replace the fuel rail?
Should I even attempt myself if an injector is indeed the culprit?
Old Oct 14, 2008 | 09:40 AM
Scottwax's Avatar
That's Mr. Detail to you
It is normal for fuel injectors to lightly tick at idle since they are a mechanical device that opens and closes. Getting a code for a lean mixture does tend to indicate a bad injector though. I don't believe it is hard to change one but make sure you vent the pressure in the gas line before attempting to remove one.
Old Oct 14, 2008 | 11:48 AM
jd885's Avatar
unplug 1 injector at a time and see if it changes your idle.... then plug it back in... hows the car running besides the CEL
Old Oct 14, 2008 | 12:07 PM
miksen's Avatar
I have no idea how to locate the injectors...can you give a clue
It will idle funny,usually in the morning at first start, almost like it is missing then goes away. Other than that is seems okay.
Old Oct 14, 2008 | 12:09 PM
miksen's Avatar
i agree and i do hear the others ticking but the ticking i'm refering to is much more pronounced
Old Oct 14, 2008 | 12:14 PM
jd885's Avatar
they are on the top... the front ones are 3 little plugs infront of the Intake manifold right near the fuel rails that should be wrapped in black tape (the rails themself in black tape).... the rears im not sure but i think they are actually under the intake manifold or way in back can someone else verify?... but definantly test when cars idleing bad
Old Oct 14, 2008 | 01:17 PM
miksen's Avatar
Thanks JD
Old Oct 14, 2008 | 01:25 PM
jd885's Avatar
no prob... good luck tho... hopefully if thats not it then it throws a better code at ya
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
chisam14
Nov 6, 2018 08:56 PM
Forge277
Jun 13, 2016 09:26 PM
