loud high pitch squeak from brakes?
Old Oct 21, 2008 | 08:09 PM
Drockb418's Avatar
i have a prob with my max im driving and when i turn left my car makes a high pitch squeak/ grind like i have no brakes, so i got new better pads and its still there. its only when turning left and from the right side (passengers side) or if i hit a bump it starts and right when i hit the brake it goes away
ANY IDEAS? its making me sooooo mad
Old Oct 21, 2008 | 08:39 PM
Drockb418's Avatar
and cv joint was replaced about 2000 miles ago
and its a 2000 max with 106k miles
Old Oct 21, 2008 | 08:42 PM
jeff5347's Avatar
check the dust shield. i hit mine once and it made a horrible noise like my brakes were gone. The shield was scrapping on the rotor. bent it away and walla.
Old Oct 21, 2008 | 08:52 PM
irish44j's Avatar
retired moderator
typical dust shield rubbing....bend it away from the rotor face and you'll be fine..
Old Oct 21, 2008 | 09:17 PM
Drockb418's Avatar
just tried it and did not help.
Old Oct 21, 2008 | 09:22 PM
Drockb418's Avatar
i sprayed brake cleaner all over it as well and no help just a lot of dust.
Old Oct 22, 2008 | 06:20 AM
Reizy's Avatar
Did you jack the front end up with the car in nuetral and turn the rotor? Try it with steering full left and right and see if you can duplicate it.
It does sound like a dust shield issue though.
Old Oct 22, 2008 | 08:43 AM
MaxManOhio's Avatar
If you have not done so, pull the rotor off. Mine had rusted metal pieces between the rotor and dust shield. Clean up all the metal with wire brush.
Old Oct 22, 2008 | 09:46 AM
tbaGd_jEw's Avatar
I would have suggested the caliper sticking...but you mentioned it only happens when you turn left...hmmm
Mar 12, 2020 12:06 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
hozay99
Sep 19, 2015 10:20 PM
bbsitum
Sep 11, 2015 04:55 PM
SusieQQ
Sep 9, 2015 12:14 PM
