small hole on motor mount
Old Oct 22, 2008 | 04:13 PM
Kevin319's Avatar
Hey guys, found another problem with my car
Recently discovered a small hole on my motor mount. It is located on the passenger side front. You can't notice it unless someone is pushing the gas pedal. My question is ... how will this affect my car? I was told by the Nissan mechanics that if I want to pass inspection, I would have to replace this mount and it will cost about $250 with labor and tax. I hope there is an easier way out ... help!
Old Oct 22, 2008 | 04:20 PM
HotshotVQ35's Avatar
get the ES inserts. stock mounts ftl.. yes there is vibration, but its tolerable
Old Oct 22, 2008 | 05:29 PM
Kevin319's Avatar
stock mounts are garbage? yeah i have noticed extreme vibration from my car ... is the "ES inserts" easy to install?
Old Oct 22, 2008 | 05:41 PM
the stock mounts need to be pressed out, and the es inserts pressed in. most local shops can do it.
http://forums.maxima.org/5th-generat...installed.html
Old Oct 22, 2008 | 06:12 PM
Kevin319's Avatar
Thanks for all your replies. I do have one more question though, since I have a 2000 Maxima Automatic, are the motor mounts going to be different? I have already done some research on reading other posts and most them were on 6spd. I also found this link
http://store.summitracing.com/partde...5&autoview=sku
Will these work as a replacement for my original mounts?
Old Oct 22, 2008 | 06:34 PM
get them from cattman, great vendor and they are $80 00-03 the same
http://forums.maxima.org/group-deals...ober-sale.html
Old Oct 22, 2008 | 06:41 PM
Kevin319's Avatar
Thanks for everything buddy! Just to make sure I order the right part,
- 00-03 Maxima and 00-04 I30/I35: F&R motor mount bushing set (Maxima only), was $89.99, now $80
Is that what I am suppose to order?
Old Oct 22, 2008 | 06:52 PM
dizmax96's Avatar
he said pass side motor mount. thanks for linking my thread
Old Oct 22, 2008 | 06:59 PM
dammit, no its not..my bad. i was talking about the front and rear on the cross member. the side mounts to my knowledge dont go bad as quick. as far as i know there are no poly bushings for the side mounts..
it was one of the 1st when i searched..
Old Oct 22, 2008 | 07:05 PM
Kevin319's Avatar
forgot to mention my car has 102k mileage on it ... so the ES motor mount are for rear and front?
Old Oct 22, 2008 | 07:41 PM
yup, both on the crossmember
Old Oct 22, 2008 | 07:48 PM
Kevin319's Avatar
Oh I get it now, do you know any sites that sell pass side mm?
Old Oct 23, 2008 | 02:40 PM
knight_yyz's Avatar
Toolie
I have been told by a few nissan mechanics that there should never be a reason to swap the side mounts, unless there is physical damage to them. Call Dave B. his number is in the stickies if you need the side mount
Old Oct 23, 2008 | 07:00 PM
Kevin319's Avatar
Thanks, I'll let DaveB know since I just received my ignition coil from him today gonna install it this Sat heh. But yeah I was told by a Nissan mechanic in order to pass inspection I would have to have it replaced. I tried to take a picture of the hole but I don't have another person to help me take the picture.
matts95max
Apr 23, 2025 10:44 AM
wyobbagy
Jan 3, 2023 12:03 PM
QueensMAX
Sep 15, 2015 04:14 AM
spidgeon
Sep 9, 2015 03:36 PM
