Cat Question
Cat Question
i have a 5th gen auto fed spec, if i were to replace the cat with a straight pipe would i get any engine lights or safe mode or anything like that?
me and my friend just removed the cat on his CRX and damn is it loud, im jealous,
i wanted to see if that would be possible with the max without any problems.
you may get the check engine light, but you will not go into safe mode or anything like that. It shouldn't affect performance in any way. But, replacing just the cat without replacing the y-pipe, won't get you a lot of gains....
Originally posted by SkylineGTR
thanks, thats all i needed to know hehe. i asked because i plan on getting the ypipe real soon and i thought if i could change the cat at the same time.
no problem... since you have fed spec emissions, if you replace the y-pipe and replace the main cat with a straight pipe, you will surely get a check engine light because you will have no cats in the exhaust at all. But it should be no big deal. You could also replace the stock cat with a Random Tech hi-flow cat.... no check engine lights then.....
pears
Sep 18, 2015 05:25 AM
Justin Kroll
Sep 2, 2015 11:06 AM
