Constant Lean
Old Nov 1, 2008 | 10:21 AM
Professor's Avatar
Constant Lean
I constantly get a lean code bank 1, it always happens , what could be causing this ?
2000 Gle
Old Nov 1, 2008 | 06:22 PM
Professor's Avatar
Since no one cares to chime in, i found the solution to the problem, I put the OEM intake back on and NO MORE LEAN CODE yay. Installed a tornado thingamabob and hopefully that will improve some gas millage. Feels a little more responsive. but to see what else i did, check the what did you do to your maxima today thread.
Old Nov 1, 2008 | 10:44 PM
dewd's Avatar
link to tornado pro?
Old Nov 2, 2008 | 07:28 AM
Professor's Avatar
Umm they sell them at Napa and other auto store, most likely you will need the KI-75 Model for the oem intake.
ive watched some vids and reviews of the product and some say 0% improvement, so its hard to say, i got mine free so there is no harm leaving it in there or not.
http://www.youtube.com/watch?v=bWFvBG6CUHk
Old Nov 2, 2008 | 01:27 PM
dewd's Avatar
i think the spin would make it more concentrated but im no scientist or no lab geek but it would sorta make sense on improving..
free is a good deal too, cant go wrong with that.. thanks for the info pro im gonna pick one up hehe
Old Nov 7, 2008 | 01:12 PM
Professor's Avatar
Its been about a week i see a slight gain in gas milage but not enough to outweigh the $70 price for the tornado, dont forget there is alot of cheap immitations out there.
Old Nov 7, 2008 | 02:26 PM
P. Samson's Avatar
Next time it would be damn helpful if you (and everyone else) included info about what you just did to the car including any "mods". AND........if you have a car that had no issues before making changes or doing work and now you've got a problem.......odds are pretty good that it's related to that work or mod. That's your starting point to remedy the now existing problem. It ain't rocket science!
Old Nov 8, 2008 | 08:53 AM
NisTech's Avatar
if noboby touched the car recently it's your airflow meter.
i would check all hoses first and listen to hissing noises looking for a vacum leak
Old Nov 8, 2008 | 12:38 PM
Professor's Avatar
i had the intake on for almost 2 years, changed filter regularly and i just started getting bank one lean all the time and massive pinging, even with 97 octane fuel, so for the eff of it i put the oem airbox on and it cured everything, not sure why after so long it did that, I had no hose leaks and all connections where tight, oh well, ill leave it oem till summer and get a better brand intake system.
Old Nov 8, 2008 | 12:45 PM
NmexMAX's Avatar
dot dot dot ...
MAF.
Old Nov 8, 2008 | 04:13 PM
Professor's Avatar
Originally Posted by NmexMAX
MAF.
OUCH!
Old Nov 8, 2008 | 10:00 PM
NmexMAX's Avatar
dot dot dot ...
Is English your second language?
Old Nov 9, 2008 | 11:09 AM
Professor's Avatar
Depends what month it is.
Old Nov 9, 2008 | 10:48 PM
NisTech's Avatar
did u tighten all clamps and plug all vacum lines??
Old Nov 10, 2008 | 12:32 AM
Professor's Avatar
everything seems to be going good now.
Old Nov 10, 2008 | 01:54 PM
Professor's Avatar
Well i counted my chickens before they hatched, After the lightning strike i replaced the MAF and today The code came back again, iam up against the wall, i cant figure out what is causing this.
Old Nov 10, 2008 | 05:02 PM
NisTech's Avatar
its a vacum leak most likely if airflow meter did not solve it. what i do is hook up scanner and look at air fuel mixture which will be minimum 25 % lean more than it should to set DTC. then i get throttle body vleaner spray and with cold vehicle spray some around intake mainafold gasket or vacum hoses. if that number changes drasticly to rich obviously or if RPM speeds up you got a leak. However you should be able to also hear a hissing noise. i suspect you have a clamp loose or a hose came off. or cracked. remove also your engine cover and have a look. if you can't find it bring it in as lean condition is more dangerous to engine components as opposed to ritch where your cat would go
Old Nov 21, 2008 | 03:16 AM
Professor's Avatar
Cant find any leaks, i tried spraying carb cleaner around the intake and all the vaccum lines when running with no change, It came back on again and now i can smell the heat from the cat in the front near the radiator when iam going up a hill only pulling 2k rpm, the cat seems to be getting super heated. something is definitly wrong, i ran a bottle of that lucas fuel treatment, that stopped the pinging wich i had even with 93 octane fuel,i just cant pin point this.
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
msellas
Sep 23, 2015 09:16 PM
lrb6805
Sep 17, 2015 04:49 PM
jfl330
Sep 4, 2015 01:44 PM
