Injen CAI air filter replacement.. where do I buy one?
Old Nov 4, 2008 | 12:03 PM
godlyone's Avatar
ahhh! cliMAX!
Where's the best place to get an injen replacement CAI for my 2000 max? thanks
Also I read that some of you guys are against oiling the filter since it may mess up the MAF. What options do I have? [the filter there now looks like it deff needs changing]
Old Nov 4, 2008 | 01:08 PM
HotshotVQ35's Avatar
http://www.2kracing.com/Product/351.html
Old Nov 4, 2008 | 01:22 PM
808MAX-SPEC's Avatar
Try Jegs or Summit Racing. The trick is to apply the right amount of oil. I decided not to get the same Injen filter(X-1011) and go with cone filter from K&N. Get the Apexi if you don't want to deal with the oiling.
Old Nov 4, 2008 | 07:17 PM
godlyone's Avatar
ahhh! cliMAX!
nothing cheaper than 60? no group deals on this stuff?
so which is considered better? apexi or injen? and if I get the Injen, how much oil should I put on it? It comes with its own oil?
Old Nov 4, 2008 | 07:54 PM
Bjs470's Avatar
Summits pretty good...I got an unexpected free hat with my order and they literally had it here in 1 day...
Old Nov 5, 2008 | 06:31 AM
ImportCarPartsP's Avatar
$53 shipped for a Injen Replacement filter for your Injen Intake.
Old Nov 5, 2008 | 06:33 AM
Or if you want this one,
Apexi Power Intake Replacement Filter (Filter Only) 80mm
Part Number: 500-A021
Manufacturer: Apexi
$61 shipped
Old Nov 5, 2008 | 08:54 AM
SmokinMax02's Avatar
For $60 bucks you my as well go with the best option and get your best bang for the buck...
http://www.courtesyparts.com/jwt-pop...1956_5834_5837&
A little more pricey, but that is the best of the best, IMO.
Old Nov 5, 2008 | 01:08 PM
Keep in mind that the filter will reside in the confines of the engine bay and size of the cone filter will be an issue.
The Injen x-1011 cone filter dimensions are:
Flange: 3"
Top Dia.: 4"
Bottom Dia.: 5"
Length: 5"
I recently got the K&N RR-3003.
Flange: 3"
Top Dia.: 5.25"
Bottom Dia.: 6"
Length: 5"
It was a PITA to install. The filter was too big to fit between the radiator hose, trans dip stick and positive battery harness. So I had to drop the splash panel and install it from underneath the car. It's a tight fit but the main thing is it's not touching anything. Pics will be available later.
My recommendation is to stick with a filter that has the same dimensions as the x-1011 and not go any larger than the RR-3003.
Old Nov 5, 2008 | 01:27 PM
... how much oil should I put on it? It comes with its own oil?
Go to any auto part store and get the K&N cleaner/oil kit. When you wash it with the cleaner, the filter will turn white. After drying it out, spray on the oil evenly so it's back to the red look. For me, I apply the oil and let it sit for an hour. Then I take some paper towels and wrap the filter to soak the excess oil. Works for me and no problems thus far.
Old Nov 5, 2008 | 01:29 PM
Revs2Hard's Avatar
BARF
There expencive and I dont belive there is any group deals going on them.
Old Nov 5, 2008 | 07:15 PM
godlyone's Avatar
ahhh! cliMAX!
Flange: 3"
Top Dia.: 4"
Bottom Dia.: 5"
Length: 5"
Flange: 3"
Top Dia.: 5.25"
Bottom Dia.: 6"
Length: 5"
are you sure that the Injen x-1011 is the regular filter that comes with the injen kit?
Old Nov 5, 2008 | 08:44 PM
My bad. I forgot the "-BR" so it should be the X-1011-BR.
http://www.injen.com/docs/other/sear...elID=85&Eng=V6
Old Nov 5, 2008 | 10:00 PM
godlyone's Avatar
ahhh! cliMAX!
is that apexi a direct fit onto the injen ?
also how does it compare?
Old Nov 6, 2008 | 11:46 AM
sublime258's Avatar
Pretty sure the Injen comes oiled, you only need to oil it if you clean it.
Old Nov 6, 2008 | 01:26 PM
You can fit any type of cone filter as long as it's dimensions are similar to the Injen's X-1011-BR because it will be recessed in the engine bay. Some cone filters like the apexi require a flange adapter/connector. Per ImportCarParts post #7, quoted filter only. You will also need to get an additional 3" silicone hose and two hose clamps to connect the filter setup to the injen downpipe. I have an old picture of the apexi setup on page two of my cardomain page. It's not a close up shot but you will see everything listed above in the photo after the MAF sensor.
All filters perform the same function, oiled or non-oil applications.
To sum up, if you're worried about he oil, then get the apexi setup. If not, then get the injen replacement filter.
97_GXE
20
Sep 17, 2015 08:12 PM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
sdotcarter
Sep 2, 2015 09:53 PM
