Throttle Position Sensor oil residue
Old Nov 11, 2008 | 07:47 PM
Love_00_Max's Avatar
There is oil residue on top of the TPS. I would assume that there is enough oil gunk/residue behind the butterfly plate that it creeped past the gasket. Should I have to clean it all over, there is only so much one can access behind the butterfly plate to clean the gunk.
Any suggestions will help.
Old Nov 12, 2008 | 03:05 AM
Professor's Avatar
Oil catch can.
Old Nov 12, 2008 | 09:19 AM
How will a oil catch can installation mitigate the problem.?
The PCV is desgined to route any oil from the escaping from pistons to combution chamber to be burnt. Are you telling me the oil is not getting burnt in the combustion chamber?
I don't see any alarming levels of oil loss either. Would a heavier oil reduce the blowby..
Old Nov 12, 2008 | 09:33 AM
Professor's Avatar
the oil residue come from the pcv valve wich is routed back into the intake and then burned off, a faulty pcv valve may be the issue, i got to empty my can atleast 2 times a month
Old Nov 12, 2008 | 09:45 AM
P. Samson's Avatar
I'm going to cover old territory again. The oil in the intake that you see upstream of the TB is normal and is coming from the crankcase vent backflowing crankcase vapors (breather). This will occur during periods of low vacuum (large throttle openings) because the volume of these breather vapors (caused essentially by blowby) is above what the PCV hose/valve can handle. This is why the crankcase vent hose is sometimes called the "blowby" hose.
Old Nov 12, 2008 | 01:31 PM
tbergma1's Avatar
Well you can take the hose from the front valve cover and pull it off of the intake and put a filter on it. On the back vavle cover you can plug up that PVC valve and then plug up the hose on the intake.
When you go to smog, just make sure you put everything back. This will eliminate any blowby from going back into the intake. This blowby causes carbon buildup on your valves and the tops of your pistons. I have been doing this to my car. i put 145k on it and the valves look clean. I have looked at stock setups and there seems to be carbon buildup on the valves and pistons.
Old Jan 7, 2009 | 11:32 AM
officer2183's Avatar
tps
hey whats up? im also hiving problems with this tp sensor... my check engine light is on and i went to autozone for a free diagnostic ( at the stealership is $110 just to plug in the machine to check why the light is on.) the diagnostic said that is the tps...any body had this problem before? how did you fix it? is it expensive? would my "bronze" extended warranty covert it?
please help..
thanks
Old Jan 7, 2009 | 11:56 AM
pmohr's Avatar
No more Maximas...
please help..
thanks
What exactly was the code?
Will your extended warranty cover it? Who knows, have you asked them? They'd know better than we would...
Old Jan 12, 2009 | 07:34 AM
the code is P2135
Old Jan 12, 2009 | 01:02 PM
pmohr's Avatar
No more Maximas...
the code is P2135
Well, you didn't answer my second question. Have you called the warranty company?
Yes, that's a TPS code. Your choices are most likely wiring or replacing the TB, as the DBW components inside the throttle body aren't serviceable.
mvm062
Nov 30, 2020 09:00 AM
97_GXE
Sep 15, 2015 06:47 AM
ag90fox
Sep 9, 2015 12:22 PM
SusieQQ
Sep 9, 2015 12:14 PM
sdotcarter
Sep 2, 2015 09:53 PM
