BLOWER MOTOR...OR RESISTOR?
Old Nov 17, 2008 | 08:38 AM
MAXIMA_STYLE's Avatar
Ok, here's the deal, my blower seemed to stop working a while back..although when i hit a hard bump it turns on anf works at any speed. Today i figured id buy a blower motor,no one has it in stock(big shock).So when i got home i had the car running and whacked the back of the motor housing with a ratchet and it turned on.Is this the motor itself or the resistor.amp? i have digital climate control.
Old Nov 17, 2008 | 08:50 AM
kukx30de's Avatar
From what you describe, it definately sounds like the motor.
You can remove the motor and check to see if it runs properly.
Side Question: When was the last time you cleaned it up? The dirt and grime getting in there without the cleaning can easily cause your motor to run harder leading it to fail sometime.
Old Nov 17, 2008 | 08:56 AM
i have never cleaned it, i didnt know i should have..... so replacing the motor should fix this problem?
Old Nov 17, 2008 | 08:58 AM
maximase86's Avatar
I love lamp.
Certainly sounds like the blower motor. However I would get it fixed soon. If you keep leaving the fan turned on and it's not turning, eventually that resistor is going to burn out as well.
S
Old Nov 17, 2008 | 09:25 AM
Prophecy99's Avatar
S
thats....good to know....
mine went last week, so now at full power its as if it was on the lowest speed setting if anything at all.
My motor/filter should be here today... so...hopefully I didnt hurt it too much.
What is the resistor exactly? part of the motor?
Old Nov 17, 2008 | 12:24 PM
Ok, well i just picked up a used one from the local "junkyard" in worcester mass....40k on it 30 bucks...that did the trick, i swear to god it feels like i got flames coming from my vents now lol....
Smackasmith
Feb 1, 2016 12:40 AM
knight_yyz
Nov 1, 2015 01:34 PM
Turbonut
46
Oct 21, 2015 08:28 PM
ballerchris510
Sep 23, 2015 08:46 PM
