Rattle on cold start
Old Nov 18, 2008 | 05:45 PM
kjchevy3's Avatar
I've noticed as it's getting colder just after starting I'll get a very noticeable rattle. It only lasts a few seconds and nothing seems out of the ordinary. Is this normal? Has anyone else experienced this? Any ideas or experiences are appreciated. BTW, it's a 2002 GLE.
Old Nov 18, 2008 | 06:02 PM
jasonmax's Avatar
http://maxima.theowensfamily.com/tsb/NTB03-060.pdf
Old Nov 18, 2008 | 09:05 PM
Scottwax's Avatar
That's Mr. Detail to you
Very typical of our cars. Mines been doing it as long as I've had it. Engine now has 140,165 miles on it and seems to run fine despite the cold start rattle. I haven't heard of anyone having any serious problems due to the rattling, although I guess if the sprockets get bad enough they'd affect your valve timing.
Old Nov 18, 2008 | 09:31 PM
Feldman's Avatar
make sure you are using the correct viscosity oil (5w30) or maybe try some synthetic if you aren't already. I know the sound probably drives you crazy but from everything i have read on the subject it isn't a major issue.
Old Nov 20, 2008 | 07:39 AM
dehaantim111's Avatar
i have the same problem and it only does it on cold mornings. bought the car new and its been doing it for about 3 yrs now. my father is a mechanic and he rebuilds engines, trannies...everything. he says its nothing major and all cars no matter how much they cost will make noises.
Old Nov 20, 2008 | 10:46 AM
'02_EMILBUS's Avatar
Mine has rattle similar to what you're describing. I've heard of claims for it being the VTC sprockets and that it does no harm. Only difference is some of us have the 3.5L and the Thread starter is talking 'bout a 3.0L
Old Nov 20, 2008 | 11:00 AM
oldngivout's Avatar
Willing to learn
Old Nov 20, 2008 | 11:11 AM
Froggmann's Avatar
As others have said it's normal. If i let my car sit for more than 2 days that dammed chain rattle scares the **** out of me but it's a common thing with the VQ motor. Sorry to say just get used to it.
Old Nov 20, 2008 | 11:27 AM
jasonmax's Avatar
throwing some good oil in the engine will make the rattling a little better
Old Nov 20, 2008 | 12:59 PM
Originally Posted by oldngivout
ouch, my bad. I guess I read it wrong or browsed over it too quickly when making that comment.
Indeed. I've noticed adding oil helps.. as i burn oil.
what is your idea of a "good oil"?
Mobil1 is what i've been using
Old Nov 20, 2008 | 01:12 PM
playboi21617's Avatar
yep ive had the same problems for 2 years now i havnt had any probs
Old Nov 24, 2008 | 01:53 PM
02nissmax's Avatar
I have an 02 max with 53K and I believe this is what I hear.
will the dealership honor this repair under warranty?
Old Nov 24, 2008 | 04:50 PM
Froggmann's Avatar
No it's just a TSB (Technical Service Bulletin) as it has not been proven to take the life out of the engine, just scare/annoy the owner.
Old Nov 24, 2008 | 04:57 PM
sublime258's Avatar
Since when is a 2002 not a 3.5L?
Old Nov 25, 2008 | 05:45 AM
02nissmax's Avatar
k cool stuff.
I was concerned because it sounds like dry lifter startup or valve train startup for this matter. I may post vids of mine when I can as reference.
Old Nov 25, 2008 | 08:48 AM
jasonmax's Avatar
Originally Posted by 02nissmax
k cool stuff.
is this the sound you were describing?
at 10s of this vid.
http://www.youtube.com/watch?v=UzwiMWC_9EQ
Old Nov 25, 2008 | 07:11 PM
02nissmax's Avatar
at 10s of this vid.
I believe on my car it sounds more ratchety and I believe it is almost right away. In this video it sounds like there is a delay in the sound.
Old Jan 17, 2011 | 10:44 AM
rebelrobx's Avatar
Hi, Just looking for updates on this valve chatter noise. Anybody eventually have problems with this or is it still nothing to be concerned about? I have a 03 SE and it makes all kinds of chatter/clacking when I drive off until it warms up, but even after that I can still hear it when driving at highway speeds when I accelerate.
thanks,
Old Jan 17, 2011 | 11:26 AM
OK.Eric's Avatar
thanks,
I still get the noise but only when it's very cold outside. Last year we had an ice storm and I didn't start the car for maybe 4 days (it was very cold) and when I did start it, it made the noise described really bad but went away after the car warmed up. I don't believe it's something to get worried about.
Old Jan 17, 2011 | 02:06 PM
rebelrobx's Avatar
OK, thanks. I have another thread where I asked this question too. Seems to be common in the 3.5 L engines. Just sounds like lifters sticking or not getting any oil. I hope it will be ok. I am original owner and I want to get at least 150K miles out of it.
Old Jan 17, 2011 | 02:40 PM
Sneaky Green's Avatar
If you can get your car on a lift I can guarantee there is all kinds of loose welds and missing nuts mainly the heat shield if you ran bad motor mounts it usually loosens things up around your pre cats just take it to a shop and get a standing up look at the bottom of your car
Old Jan 17, 2011 | 02:41 PM
Scottwax's Avatar
thanks,
If the passenger side engine mount is going out, the engine will be noticeably noisy until it fully warms up.
Old Jan 17, 2011 | 04:45 PM
Bonafyd's Avatar
Hey OP I was having sorta the same issue,I jacked up my car & started tapping around & found out it was my catalytic converter shield,I removed it & the noise has stopped...it might not be the issue your having but it's worth a shot to check it out since the noise only happened on cold starts like you stated.
gustavison
Oct 4, 2015 06:50 PM
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
trungg86
Sep 4, 2015 04:58 AM
