Catalytic converter is rattling like crazy
Old Nov 25, 2008 | 11:24 AM
02_Maxima_6sd's Avatar
I was at the shop today and was told my rear cat is shot. I tried calling several places to see if a universal cat will fit but did not have any luck.
the guy at the shop stated I need to get one that is Bank2. if a universal is not a solution have any of you' all replaced your rear cat and if so how much did you spent on the part?
I found an Eastern Catalytic Converter for $259.00 and a Catco for $269.00 is that a good price?
I have an 02 max 6-spd
thanks in advance.......
Old Nov 25, 2008 | 01:55 PM
CMax03's Avatar
Get a flanged Cat from Warpspeed (Carsound/Magnaflow) $100.00, they fit perfectly...
Old Nov 25, 2008 | 07:47 PM
Scottwax's Avatar
That's Mr. Detail to you
The rear (main cat) or one of the ones that comes off the exhaust manifolds?
Old Nov 25, 2008 | 08:50 PM
nsnrider's Avatar
i was able to find both pre-cat and main cat in aftermarket. not as good as the OEM though but much cheaper.
Old Nov 25, 2008 | 09:08 PM
hi-tek22's Avatar
where did you come across them at if you dont mind me asking....granted i have an 01 and you have an 03...Id still be interested in seeing the story
Ive got to replace my front precat, and when i reset the SES light it comes back on after a few hundred miles.....
Old Nov 27, 2008 | 09:03 AM
Let me see if I can describe it a tad more thoroughly. (Starting from the front bottom of the car going towards the back) First cat is the one that looks like a small bucket.This is the front cat. The one I need is the next one that follows the front cat. It looks like it is connected to same pipe as the first however it has another little pipe that is connected somewhere on the engine.. The third cat is the one closer to the muffler. I tried to get the exact part name and the guy stated it is a rear cat bank2..
Sorry to sound follish by no knowing the proper term for the part I need.
thanks.....
Old Nov 27, 2008 | 11:52 PM
2000MaximaSE's Avatar
that doesnt make sense... The bank2 cat is the "bucket" one between the manifold and the downpipe at the very front of your car.. He must mean your downstream pre cat which actually connects to both manifold bank 1 and 2. Do a search for precat and look for one that looks like a mini main cat.. Thats what you need apparently
Old Dec 5, 2008 | 12:47 PM
So I figured out how to put a diagram for you all to see and further assist me with my rattling prob.
thanks in advance........
http://forums.maxima.org/members/02_...at-called.html
Old Dec 5, 2008 | 01:48 PM
hi-tek22's Avatar
thats the "rear" precat...it gets eliminated if you were to add a y pipe...the one directly to the left in the photo, is the FRONT precat and can be seen if you look directly in front of the radiator fans
Old Dec 5, 2008 | 09:11 PM
So what do you all think my options are? Replace it with an after market cat, or go with a y-pipe? If I select the y-pipe what happens to the 02 sensor?
Any benefits of going with the y-pipe?
If any of you replaced this same cat and can comment on price/vendor I would appreciate it a whole lot.
Old Dec 5, 2008 | 10:15 PM
CMax03's Avatar
Warpspeed: $100 flanged Carsound or $185 flanged Stainless substrate unit....
Old Dec 9, 2008 | 07:45 AM
Okay, so I called Warpspeed and they stated this diagram does not look to be for my 02 max...I got this diagram from Nissan plus I also found one online that matches. New symptom, rotten egg smell started on Saturday..
Any suggestions as to what else I can do?
Old Dec 15, 2008 | 12:49 PM
thanks fellas for your help!!!
Old Jan 4, 2009 | 10:47 AM
hoppers69's Avatar
Hey 02_Maxima_6sd,
Did you get your cat for your 2002 maxima from warpspeed? Did you install it and if so - how difficult was it i.e. was it rusted on there or not too bad?
I'm just curious since i too have a rattle and 2 mechanics have said it was the cat (I thought it was the Timing chain tensioner though).
For $100 - I may try out the warpspeed cat if that is what you went with. thanks!
Old Jan 4, 2009 | 06:53 PM
Hey Hopper and welcome to the forum!
What I needed was not the main cat which runs for about $100.
The converter I ordered is called a precat "bank1" which is the cat that is by the firewall. There is another precat known as bank2 which is right in the front where your radiator is located.
Who diagnosed your issue? It is imperative that you get a few free estimates to make sure you are told which cat you need. You can call "Dallas" from warpspeed and he can order one for you. the part I ordered is the Catco brand #1079 (bank1 precat) and I paid $259.00. Dallas was very helpful and knowledgeable that is why I gave him my business.
Joe's Muffler shop in Addison, TX. did the install for me. He had a difficult time removing the precat so he charged $200.00 for the job. I still saved well over $500.00.
hope that helps.....
Old Jan 5, 2009 | 10:45 AM
hoppers69's Avatar
Thanks 02_Maxima_6sd,
I am still trying to get a few different opinions as Im now also reading all about the different cats on this car.
My opinion is that my "rattle" is the TC tensioner, but a mechanic said he was under the car when another tech revved the engine and heard it in the cat. Now I just need to ask him WHICH cat did he hear it in
Good info in this thread though, thanks again!
Old Jan 5, 2009 | 10:53 AM
CMax03's Avatar
Open the exhaust or remove the cat, the metallic laminated stainless steel gasket is reuseable. Remove the cat and inspect it! Or buy my used cat for $150 or just call WarpSpeed...If it is your cat you may wanna investigate why it failed...possible too rich condition?
Old Jan 5, 2009 | 05:13 PM
Progress's Avatar
It's business time.
Do you trust the shop that diagnosed the cat as shot? Why do they think it's shot? Is it throwing codes? What is exactly rattling?
Old Jan 6, 2009 | 11:34 AM
My max did no throw out a code. It just rattled and that bugged me because Maxima's are suppose to look great, drive smooth, and sound nice.... 2 out of 3 was not satisfactory to me..
Old Jan 6, 2009 | 06:13 PM
Progress's Avatar
It's business time.
What if it's just the heat shield?
user 11122324
42
Jul 18, 2022 03:35 PM
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
Garrettz459
Sep 28, 2015 02:50 PM
carid
Sep 9, 2015 05:06 AM
