2001 maxima door lock system negative or positive trigger?
Old Nov 26, 2008 | 03:51 PM
imported_D_Roc's Avatar
i'm installing a remote start and for the door lock and unlock i need to know weather the car have a positive or negative trigger so which does it have?
thanks
D
Old Nov 26, 2008 | 05:59 PM
VQP0WER's Avatar
negative
Door Trigger Wire (-): green for the drivers door in pin 1, red/blue for the passenger front door in pin 2, and red/white for the rear doors in pin 3. Use all 3 wires and diode isolate each.
Door Trigger Wire Location: keyless entry module
Old Nov 29, 2008 | 10:42 AM
ok thanks man but i don't think i have to go through the diodes only have two wires for it,
but i have another question, Where is the "Smart Entry Control Unit located" from the wiring diagram i downloaded off the website of the remote starter it says its located to the passanger side of the steering coloum and i did find a white box with 3 wiring harnesses going to it one white connector and two grey the white one is the one with most pins (24) but the Power lock and Power unlock pins are number 35 and 23 and also says (Type B) what does the Type B mean.
this is the wiring diagram i downloaded
thaks
D
Old Nov 29, 2008 | 12:06 PM
VQP0WER's Avatar
Yes, the control unit is on the passenger side of the steering column, but not on the column itself.
Not sure what 'type B' is either.
Old Nov 29, 2008 | 12:30 PM
ok so its the white box with 3 wire harnesses? how do i igure which is which number and does that wirechart/colors look correct?
Old Nov 29, 2008 | 01:39 PM
VQP0WER's Avatar
From the ESM:
54 GY Door lock actuators Door lock & unlock switch (Free , Lock)
55 W/B Driver door lock actuator Door lock & unlock switch (Free , Unlock)
56 GY Passenger and rear doors lock actuator Door lock & unlock switch (Free
, Unlock)
Old Nov 29, 2008 | 02:39 PM
thanks a lot man, this thing confuesd the hell outta me
Old Nov 29, 2008 | 05:56 PM
also this is the wires form the unit do i have to do the diode thing in this unit?
Old Nov 29, 2008 | 06:09 PM
VQP0WER's Avatar
You shouldn't have to touch the diodes.
What system is this?
Old Nov 29, 2008 | 06:30 PM
its a bulldog security deluxe 200, right now i'm having problem figuring out which wire is which on the SECU the colors match according to the wiring diagram but not the pin number,so i don't have to use diodes on this one?
Old Nov 29, 2008 | 08:00 PM
VQP0WER's Avatar
Do you have the service manual for your car? I would go off that before I go off of some security system diagram.
I'm a little to tired to look at the manual now, but I will take a look tomorrow...
Old Nov 29, 2008 | 08:18 PM
the FSM? yea i did that thing is even more confusing, i would have let a shop do it for me but now its too late i guess, thought i can do it myself coz i did an install on a 06 camry and a 93 mercedes and they were wicked easy to do but this car is a headche. but yea no point looking at the fsm
LilVito
Oct 25, 2019 08:12 AM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
kjm900r
Aug 5, 2015 07:14 AM
wpr
Aug 5, 2015 03:28 AM
