Torque vs. HP. This is confusing
Old Nov 13, 2001 | 12:10 PM
soundmike's Avatar
Very sound, Mike
Just read the posts here and from what i understood is:
If you have two 3.5L (VQ) engines with same torque, HP should be the same, at least theoretically, right?
Now if that's the case, is it possible to have the same amount of HP and not the same amount of Torque?
I'm asking because the 02 Pathfinder puts out 19 lb/ft. more torque over the Altima/Maxima yet has pretty much the same horsepower rating (240 for auto, 250 for manual)
How's that possible?
Thanks.
Old Nov 13, 2001 | 12:23 PM
UMD_MaxSE's Avatar
Got Bent?
SUVs are tuned a bit differently. They have more torque available down low than cars do. Trade-offs are made between having power down low vs power up high. Although the pathfinder engine has more grunt down low, it may run out of breath at higher rpms, whereas the maxima/altima engine will have a stronger high-end.
Old Nov 13, 2001 | 12:27 PM
HulaMAX's Avatar
Re: Torque vs. HP. This is confusing
Thanks.
Motors with the same HP will not necessarily have the same Torque. Engineers can do a wide arrange of tuning specs (compression ratio, bore, stroke, etc) to get what's needed from an engine.
Usually, trucks or SUV's are built with more torque because they are built for pulling a trailer or some type of off-road use. Hope that helps...
Old Nov 13, 2001 | 12:30 PM
soundmike's Avatar
Very sound, Mike
Ah. I see, that explains why the Pathfinder had a lower top-speed based on what i saw on the gauges.
Anyhow, based on that explanation... would you agree that the Alt/Max are also tuned differently and as such the Max really does have 255 while the Alt has 240hp?
Old Nov 13, 2001 | 12:33 PM
HulaMAX's Avatar
Thanks.
UMD_MaxSE's Avatar
Got Bent?
well, I think Nissan does claim that the altima engine and maxima engine are tuned differently. How, I don't know... could be a number of things: ECU, intake, exhaust... But, a dyno would uncover what real differences there are between the two engines and if the 15 hp difference is for real or not.
Old Nov 13, 2001 | 12:53 PM
soundmike's Avatar
Very sound, Mike
Speaking of dyno's. I'll be doing mine in an hour and was wondering if i should fill it up with gas before i do that or just keep it as it is now? (1/8th tank).
Any other tips i should take note of before doing the dyno?
Thanks.
Old Nov 13, 2001 | 01:01 PM
UMD_MaxSE's Avatar
Got Bent?
Thanks.
keep it at a 1/8th tank.... other than that, nothing special needed
Old Nov 13, 2001 | 03:34 PM
Max_Gator's Avatar
Thanks.
It doesn't matter - amount of gas only matters at the track (you know - weight!).
Not much you can do - if this isn't too late already - aside from getting there early so your engine can cool. You can lose some hp if you've got "heat soak." They'll open the hood for you.
If there is a fan nearby, let it blow on the airbox intake. That'll at least give a little air flow like you'd get on the highway.
I'd also have them do one run in 3rd and one in 4th.
Good luck!!!
Old Nov 13, 2001 | 04:07 PM
SuDZ's Avatar
Yeah at 8 pounds a gallon the weight will help you out some if you keep it down. I mean a full tank is 112 - 120 pounds alone.
SuDZ
Old Nov 13, 2001 | 04:20 PM
Matticus's Avatar
SuDZ
Well, being that the car is not moving, and the gas tank is in the rear of the car, gas wouldn't really be an issue. At least not enough to make any difference.
Old Nov 13, 2001 | 04:21 PM
soundmike's Avatar
Very sound, Mike
Well, guys here's the dyno. Too bad i didn't see that post about running it in 3rd and 4th.
http://forums.maxima.org/showthread....threadid=78508
Old Nov 13, 2001 | 06:03 PM
spaaz14's Avatar
Gas is ~6.5lbs per gallon, water 8lbs per gallon. A really good example of a slower car feeling faster is the Miata. Not many people believe that its 0-60 is high 8's tolow 9's (previous powerplant).
Old Nov 14, 2001 | 01:43 AM
Neice Anne
[QUOTE]Originally posted by soundmike
[B]Just read the posts here and from what i understood is:
Well, your assumption isn't true. Look at the 92-94 SE's VE engine. It has 190 hp with roughly the same torque. The 95's VQ had 190 HP but around 202 ft/lbs of torque.
Old Nov 14, 2001 | 05:17 AM
soundmike's Avatar
Very sound, Mike
Re: Re: Torque vs. HP. This is confusing
Well i could understand that given the different engine steppings. But of the same family? (VQ)
[QUOTE]Originally posted by Neice Anne
[B]
Old Nov 14, 2001 | 06:29 AM
i•maxx's Avatar
…good answer!
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
AboveDaCloudz
Oct 8, 2015 11:25 PM
foodmanry
Sep 24, 2015 12:02 PM
