Odd...could Techron fuel injector cleaner cause a temporary O2 problem?
Old Dec 8, 2008 | 10:33 PM
Scottwax's Avatar
That's Mr. Detail to you
About 30 miles after adding a bottle of Techron fuel injector cleaner, my SES light came on. P0037, heated O2, bank 1 rear. Reset it and 40 miles later it was back. Reset it again and took 150 miles to come back on. Reset it about 8-9 times total and the mileage before it came back on varied from 30-40 miles to 100-150. By this time it was 3 tanks past the Techron f/i cleaner and after i reset it the last time, the SES light has now been off for close to 900 miles. I'd already replaced it in April and wasn't happy it apparently had already failed. Could something in the Techron cleaner maybe coated the end of the O2 where it sits in the exhaust stream and affected it?
Of course, now that I mentioned the light has been off, I probably jinxed it.
Old Dec 8, 2008 | 10:46 PM
The Law's Avatar
I R The Law
I've ran that stuff before I had headers and that problem never came up. Might be a faulty sensor
Old Dec 9, 2008 | 12:14 AM
2K2Beast's Avatar
I know that seafoam sometimes causes issues with o2 sensors but that is when you use it through the brake booster line to directly feed it into the intake......not all seafoam gets burned and some sits on the o2 sensor......but to use techron through the gas tank...???
Old Dec 9, 2008 | 05:26 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I use it every 5k miles, which brings me up to 9 applications at present. No problems here.
Old Dec 9, 2008 | 05:40 AM
maxipower's Avatar
so is it true because someone told me to use a pint of kerosene mixed to full tank of gas helps clean those injectors,,,i thought to myself ,,no way would i ever put kerosene in my tank but anyway what are your thoughts or feedbacks on this idea,,,i have an 01 SE...in excellent condition..
Old Dec 9, 2008 | 01:17 PM
NisTech's Avatar
you get a code for heater part of the o2. it has a heater that heats up the o2 so it can reach operating temp faster. i highly doubt additives could cause that.
Old Dec 9, 2008 | 07:13 PM
Scottwax's Avatar
That's what I was thinking but I thought I'd ask since it happened so soon after using it and seems to have cleared up.
Maxboy23
55
May 1, 2025 06:09 PM
BkGreen97
Apr 2, 2016 05:47 AM
gustavison
Oct 4, 2015 06:50 PM
conansriver
Sep 11, 2015 10:26 AM
