Fog light rewire for 2003 Maxima SE
Old 12-09-2009, 07:33 AM
  #41
1991tsi's Avatar
I want to alter this slightly to be able to use the fogs completely independent of parking lights. The 00-01 writeup on vqpower.com does it this way, but their wire colors are different... time to investigate.
1991tsi is offline
Old 12-09-2009, 08:00 AM
  #42
mist max2000's Avatar
www.shiftice.com
check it out..
mist max2000 is offline
Old 12-09-2009, 08:06 AM
  #43
Rochester's Avatar
Originally Posted by mist max2000
www.shiftice.com
check it out..
No, you missed it. He wants to use fogs without the runners. Let's see what he comes up with.
Rochester is offline
Old 12-09-2009, 08:14 AM
  #44
Stereodude's Avatar
I'm not sure you can do that short of completely bypassing the stalk in the car. I tried to reconfigure my fogs so they wouldn't shut off when I flashed my high beams, but the switching appears to be in the stalk which meant far more trouble than I was willing to tackle so I left it alone.
Stereodude is offline
Old 12-09-2009, 09:22 AM
  #45
1991tsi's Avatar
Well, trying to decipher the relay - IIRC its a normally off with a signal from the stalk and a 12v supply from who-knows-where. The question is, will the stalk send a signal with all the other lights off... will do some multimeter probing after work.
1991tsi is offline
Old 12-09-2009, 09:35 AM
  #46
josh662234's Avatar
Originally Posted by Ahmad_1290
so are you just using a splice to connect the fog wire to the taillight wire? if so.. Can you just use one of those little connectors?
read the how to. yes.
josh662234 is offline
Old 12-10-2009, 10:46 AM
  #47
showstoppa01's Avatar
Pleas Help Fog light rewire Question??
Hey whats up guys. I know this mod is not street legal (cant drive around with it without the headlights) But how about inspection??. Anyone from New york would know if the inspection station would actually check to see if your fogs come on with your headlights and would you fail? Any one from other states can help me out too if they know the regulationS for there state as well? Please Help
showstoppa01 is offline
Old 12-10-2009, 02:13 PM
  #48
CustomLowz's Avatar
You can have the fogs on without the headlights legaly. There have been a few dodge vehicles in my family that do that from the factory. There is nothing to worry about.
Also, I am from Upstate NY and ALWAYS have my fogs on only.
CustomLowz is offline
Old 12-10-2009, 04:51 PM
  #49
1991tsi's Avatar
lets post this again in the correct thread: tonight I confirmed that our fog stalk switch supplies a ground to the fog circuit independent of any other lights being on or off. so all this should take is a 12v supply that is on with the ignition but independent from any other lights...
1991tsi is offline
Old 12-10-2009, 08:13 PM
  #50
Thanx alot
Old 12-11-2009, 02:55 PM
  #51
1991tsi's Avatar
Modified shift_ice 5.5gen fog rewire
this will give you fogs independent of ALL other lights, stalk control, and fogs will go off with the key so you don't forget them.
here's the shift_ice link: http://www.shiftice.com/fog_rewire.html
this is basically like the 5.0gen rewire here: http://www.vqpower.com/v2/articles.php?article_id=24
isolate the 'air con' relay, its easier if you take it out of the box.
splice the BLUE WITH SILVER DOTS wire from the fog light relay into the PINK WITH BLUE STRIPE wire from the air con relay. the blue with silver dots wire has plenty of slack that you can pull up from the wire loop going into your fender. attach the end from the fog relay into the pink with blue stripe wire (don't cut this one). Cap/tape off the defunct end of the blue with silver dots wire going into the car.
now do this (the bottle of brake fluid will allow you to see that the fogs are on if you don't have a helper):
1991tsi is offline
Old 12-11-2009, 06:31 PM
  #52
CustomLowz's Avatar
so basically... Daytime Running Fogs?
Old 12-11-2009, 08:48 PM
  #53
eh im adding to the thread.. i like how they look with the running lights. . . (and no i dont have that grill anymore,.. i have the stock one in.. i was trying things..the one on the ground is a nissan burger delete one that i made and never installed .. meh) oh and yes.. those are 5,000k HID's
Old 12-11-2009, 10:04 PM
  #54
Demodded and Forgotten
rroderiques77's Avatar
Interesting write-up. Going to do it as well.
rroderiques77 is offline
Old 12-16-2009, 01:41 AM
  #55
a33_ridah's Avatar
sweeet thanks to 1991tsi for figuring this out...........iv had the shiftice way done for months but wanted independent control as well.
a33_ridah is offline
Old 02-11-2013, 03:43 PM
  #56
Sdonadio's Avatar
What kind of bulb is the stand by bulb in the headlight and where can I find it?
Sdonadio is offline
Old 02-11-2013, 06:06 PM
  #57
Go BUCKS!!!
SEmy2K2go's Avatar
Seriously? He made that post over 3 years ago.
SEmy2K2go is offline
Old 02-11-2013, 06:51 PM
  #58
Rochester's Avatar
There's that, sure. But what do you suppose he means when he refers to a "stand by bulb in the headlight"? My best guess is he means the little parking light.
If so, it's a very standard 194 Wedge Bulb. About as common as house flies.
Old 02-11-2013, 07:56 PM
  #59
lilmoes4g63's Avatar
You will love this mod with HIDs. Car looks sexy and mean just rolling with fog lights on. I also put white LED lights to replace my parking lights. So the color matches
lilmoes4g63 is offline
Old 02-11-2013, 08:02 PM
  #60
quick-e's Avatar
This mod with my Max is the first mod I did. The relay rewire is the fastest easier way ive seen. In my Altima I cut and rewired to another switch which worked, but that was more like and hr this was more like 20 mins or so. O and I love th oem switch still being functional.
quick-e is offline
Old 02-11-2013, 08:07 PM
  #61
Go BUCKS!!!
SEmy2K2go's Avatar
UGH...this is what happens when new members post in dead threads.
Old 06-12-2020, 06:21 PM
  #62
jcp2's Avatar
I know this is an old thread. I came across it when I lost the DRL function of my headlights when I switched to LED on my 2001 Maxima SE. I'm so glad I found it!! Now I use my LED fog lights as DRL's after I patched the Fog light relay power into the Air Con Pwr. I just wanted to say thanks guys for the info. I look forward to being part of this forum. Stay healthy and safe
John
jcp2 is offline
EuroDriver
09-14-2015 06:08 PM
wingsfan24
08-15-2015 07:35 PM
09maxshawn11
08-09-2015 01:13 PM
MikesChevelle
08-06-2015 11:36 AM
Blackwind
08-05-2015 06:35 PM
Quick Reply: Fog light rewire for 2003 Maxima SE
