Did the free STS mod... My impressions...
Old Jan 3, 2009 | 08:11 PM
kcxd35's Avatar
Honestly....The car should have been made like this, there's no point for all that extra distance...It took me about 2 hours cause it's cold outside and I was eating and relaxing and stuff while working, anyway here's the pics...
Also I used a 8mm bolt (the head of the bolt was 14mm) and I used a 9/32 drill bit. I went to a local (cheap) hardware store cause autozone, lowes, home depot, and advanced auto didn't have metric taps which is stupid...
I used an 8-1.0 metric tap
The bolt i used was the caliper bolt which i got from nissan cause it has a smooth surface and then the threads and the smooth surface is the same length as the shifter bushing.
Anyway I marked the hole with a pen through the old bushing and I started to drill and everything went smoothly and then I tapped the hole by just putting the tap over the hole and turning it slowly till it went in and stopped...
Also you don't have to worry much about over drilling the hole cause if you feel the bottom it's a very thick piece of metal and when you feel it, You will understand that it's not coming out of there...
All in all I absolutely love it, I will post up a video tomorrow if people say there waiting for one so you can see the difference in shifting, Anyway i love it and here are some pics...
More info at my cardomain...
Any questions, feel free....
Old Jan 3, 2009 | 09:35 PM
Kevin319's Avatar
Sorry for being a noob but what is the benfit of doing this?
Old Jan 3, 2009 | 09:37 PM
DrunkieTheBear's Avatar
Turbo'd Saab
Shorter throws, quicker and easier shifting
Old Jan 3, 2009 | 09:54 PM
Kevin319's Avatar
I'm guessing an automatic would have no use for this?
Old Jan 3, 2009 | 09:57 PM
Turbo'd Saab
shifting an automatic already has some short throws
Old Jan 3, 2009 | 10:02 PM
tyler5619's Avatar
um. no.
i can't tell if you're joking or not...i sure hope you don't throw your PRND21.
Old Jan 3, 2009 | 11:32 PM
Turbo'd Saab
Originally Posted by tyler5619
um. no.
you don't know me very well
Old Jan 3, 2009 | 11:42 PM
redmaxpa007's Avatar
i SeE what you did therE
Old Jan 4, 2009 | 06:59 AM
mist max2000's Avatar
thanks for posting this. pics look great,... do you have the link to the orig. one that you followed u can post in here by chance..
only ?'s : how deep do you drill..from what ur saying,.. is the a point where the bit wont drill anymore?
how much was the caliper bolt?..did u just ask nissan for a 'maxima caliper bolt'?
nice bushings ..in for video
Old Jan 4, 2009 | 08:04 AM
pmohr's Avatar
No more Maximas...
Tapping the hole IMO is pointless, it just adds more of a PITA to the whole experience. A bolt and a locknut, and you're good to go.
Old Jan 4, 2009 | 08:18 AM
so your saying.. drill the entire way through the metal shifter bracket?and catch it underneither with a lock nut?
Old Jan 4, 2009 | 08:20 AM
pmohr's Avatar
No more Maximas...
That's what we did on Merlyn's car, quick and easy.
Old Jan 4, 2009 | 08:38 AM
PulsarGTS's Avatar
I kinda agree, drill all the way through and still tapped but looking back on it, I didn't really need to tap. The metal is very hard and it sucked trying to cut those threads.
Old Jan 4, 2009 | 08:51 AM
kcxd35's Avatar
Bolt and nut method:
I agree the tap is a bit over board but i didn't want to drill all the way through the metal and it's not like it's just a few mm's.... it's a thick hunk of metal and you would need a bolt about an 1" 1/2 to 2" long, It kinda curves from a thin area to a thick area and i tried to center it more or less so it's not too close to that other **** thing to the left, I wanted it to look like part of the car and indeed it does look like a factory job...
The bolt:
It's the 14mm bolt that need's to be removed for a brake pad change...It has a smooth surface and then the threads, The smooth surface is the same width of the bushing that's on the shifter linkage and since it's a brake component....It's strong....
Nissan part number: 44141-4b000 (Pin Bolt)
There are some pics of this on my cardomain page 4
original post:
http://forums.maxima.org/5th-generat...-free-sts.html
You can just drill and bolt but I prefer the feeling I felt when I was finished... It looks like it should be there and I feel like I accomplished something lol
When I got my car, I always said I would go the extra step..Just look at his pics and look at mine...
How deep did I drill:
I drilled a little under the amount of threads on the bolt...So it was about 1/2" maybe, Just use your best judgment, when you look at the hole and the threads on the bolt you will know when it's right and honestly you can't go wrong cause your threading it to a specific size, the bolt will just catch and screw till tight...
I just did this post cause I felt the original one lacked enough pics and full detail into everything you need and what to do - No pun intended to the original post and all major props given to him...
I will post a video today, just give me a couple hours...
Old Jan 4, 2009 | 12:09 PM
great info.. thread is bookmarked
Old Jan 4, 2009 | 04:01 PM
Maxgig's Avatar
This is a "mod" that I'm going to try as well. I bought 2 8mm bolts from Lowes today, the lithium grease and 8mm tap from O'Reillys and tomorrow I'll get the hand drill.
This is a functional mod that I'm hoping will give me similar results that some of you guys experienced. Thanks for posting the pictures and the facts behind them.
Old Jan 4, 2009 | 04:40 PM
mymaxi41691's Avatar
is this only for 6spds?
Old Jan 4, 2009 | 04:41 PM
pmohr's Avatar
No more Maximas...
Yes.
Old Jan 4, 2009 | 04:52 PM
kcxd35's Avatar
http://www.youtube.com/watch?v=XrqZeb3KJeI
Here is the video I promised, Hope you can see the difference...
Old Jan 5, 2009 | 11:39 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
You just hurt my feelings......
Old Jan 5, 2009 | 11:58 AM
ZIPPIN's Avatar
Mauja He Mauja
Did you already have the ES bushing? It would have been nice to know how much difference they made.
Old Jan 5, 2009 | 12:40 PM
kcxd35's Avatar
^ Very true, I already had the bushings so don't know how much they helped but the stock one's are crap, they broke just taking them off...
Old Jan 10, 2009 | 11:40 PM
DOHCtorJT's Avatar
Did it to my car tonight, totally worth the 20 minutes of effort. I wish I had done it sooner! Feels like it should have been from the factory.
mkaresh
Mar 12, 2018 06:48 PM
D Mason
Jun 21, 2016 04:43 AM
