Idle Air Volume Learning 2000-2001
False.
My idle valve fried and I even drove it like that for acouple days.
The only thing that blew was the fuse for engine control which is for all 4 02 sensors.
The idle was alittle high after replacing, but it learned to idle just by driving it.
I used a aftermarket borgWarner.
2001 infiniti i30 IACV
I just replaced the IACV and I am still getting the same code along with these symptoms
Symptoms:
Poor acceleration with pinging as the car went up hills.
Occasionally maxed out RPM at approx 3500 as if there was a governor on the engine.
Hesitation in taking off from a start, especially when engine is cold
Transmission appeared to be slipping (extra scary as I had just done a tranny fluid flush prior to this symptom)
SES light comes every day or two with the code P0505
I believe I need to do the reset procedure...can anybody tell me the easiest way to do this?
Symptoms:
you asked earlier if the ECM has to be replaced at the same time, the answer is not always but you need to pull the ecu and look for damage (burnt chips). if you see it send the ecu for repair and replace your iacv with new oem iacv.
org member maxiiiboy has put together this document here which is good reading for this problem
https://drive.google.com/file/d/0B6O...1fNlF5QjQ/view
there is also good info in this thread here:
https://maxima.org/forums/5th-genera...d-seconds.html
good luck
ecm is at floor board between driver and passenger, yes. you'll need a 90 degree screwdriver or small ratchet set. at some point they changed from screw to hex head, i'm not sure when. this video should be helpful:
yes, this typically takes care of it
Yes I have watched all 6 of the videos ..this is one of the few ways I heard the ecm needs to be replaced after the iac motor has been replaced...I guess the next step is to check if the ecm is ok...the screws are pretty difficult to reach.
:confuse d:
:confuse d:
- CPS (both POS and REF)
- MAF
- Engine coolant temperature sensor
- TPS
- PNP switch
- PS oil pressure switch
- AC switch
- Ambient Air Temperature Switch and Intake Air Temperature sensor
- Absolute pressure sensor
- VSS
- Other: ignition switch, battery voltage
Excellent post, thanks!
I had downloaded these steps from a manual I found online, but ended up rigging it as I couldnt get through them due to it not staying on without the addition of my foot on the gas pedal.
So my 2000 gle A/T started doing strange things, like revving up and down from idle to around 1500rpms when I put it into park.
It gave me the service engine soon light with a po505 code. I did some research, and then decided I would clean my throttle body as well as my iacv. After doing those things, the issue stopped and surprisingly the ses light went off as well. Then a month or so goes by with it running fine and it starts doing the same thing, and then stopped completely and wouldnt let me put it into drive and wouldnt stay running unless I held my foot on the gas pedal. I ended up going to the pull-a-apart near me and snagged two iacv and a maf sensor. I had tested my iacv before initially and at this point again also and found that it was working after I first cleaned it (the valve and throttle body), but then a month or so later when I tested it again when getting the issues it wouldnt move up and down when turned to the on position in the car. So I installed the new (old) maf sensor and new (old) IAC Valve and it worked for another couple of weeks. Once connected it moved the IACV up and down when turning ignition to on position. (not running)
Then it all came tumbling back a few weeks later (the ses light never went off after I replaced these). Now I was unable to drive it as I couldnt find a solution. (and still havnt officially)
So what I did was I took the throttle cable and tweaked it while someone kept their foot on the gas at a good idle speed 650ish and then tightened the throttle cable back up. It idles higher at around 850 when I put it into park, but im just glad I am able to drive it as I figure the rest of it out. It also spit out a o2 sensor code for the front passenger side bank but I have already replaced so many o2 sensors on this that I dont wanna even think about it anymore.
Any help would be greatly appreciated.
I guess my question is how would I go through with this procedure if it wont run without gassing it/being rigged like this? Does this mean that I will have to have somebody with a consult II do the work now?
Thanks for all the help!
But, first things first: Focus on your P0505. I am pretty certain that your IACV is fried, and that it shorted the associated ECU transistor driver. Proceed in the following order:
- Read the document about ECU failures (link in my signature, below, 2nd link, or 3rd line). Make sure you understand the issues you are facing!
- Get a new IACV from Rockauto.com (Hitachi only: https://www.rockauto.com/en/catalog/...ac)+valve,6072, $109.79 at RockAuto).
- Get your ECU fixed - suggestions and links in the document.
- Replace both your IACV and your ECU, while undoing your "patch" at the same time.
Good luck !
Stru
Aug 14, 2018 09:17 PM
cdoublejj
Nov 22, 2014 08:17 PM
