CODES CODES CODES!! SMH!!
Old Jan 8, 2009 | 07:39 AM
BLACKKILA.GTR's Avatar
Well at first it was just a knock senso, i changed it out but it came bak
so as it stands i have a total of 7 codes !!!smfh!!!
p0455 (x2)
evap emission contro leak
p01448
manufaturer contro aux emission control
p0327 (x2)
knock sensor 1 ccircuit-low imput bank one or 1 sensor
p0171 system too lean bank 1
p0171 system too lean bank 2
ok im not t oo sure where to begin so if someone can guide me on how to fix these problems it will greatly be appreciated, and the cel does not stay on all the time it will be here for a lil and the it would off... this started happening after had i put my intake spacers on.... not too sure if that would help..
once agaiin thanks for any help!!
Old Jan 8, 2009 | 08:12 AM
alxdagreat1's Avatar
My 2000 gave me a bunch of codes one time also, but it turned out to be the MAF sensor malfuntioning. Is your car acting strange? if so what is it doing?
Old Jan 8, 2009 | 10:20 AM
njmaxseltd's Avatar
The fact that this started happening after you did the intake means that where you should start looking. Lean codes are assosiated with intake leaks. That is probably the source of your problems. Go over the intake again, once you get the lean codes to go away, see if any others come back.
Old Jan 8, 2009 | 10:22 AM
knight_yyz's Avatar
Toolie
answered your questions on the other forum
Old Jan 8, 2009 | 11:04 AM
the car doesnt really act funny... at certain times it would idle a lil funny , the needle would be normal but i listen to the way it idles and it sounds a lil funny.. but it drives good pulls strong on the highway.. thats wat had me a lil stumped on the whole lean issue...
on the spacers it said dont over rtv seal it so i was very carefull on the amount i put.. and the car sat for a whole night b4 i even started it up so that should of been enough time to let the sealant dry...
i figure if its the spacers shouldnt it have thrown a code a lil sooner?? the spacers were put on around thanksgiving..
Old Jan 8, 2009 | 11:07 AM
knight_yyz's Avatar
Toolie
i thought you did the spacers recently and it threw codes right away.
Old Jan 8, 2009 | 07:18 PM
MoncefA33's Avatar
P0171 = MAF.
Knock that out and see what happens after.
Old Jan 9, 2009 | 04:41 PM
ima check my intake today.. im wondering if my couplers after the maf could be taking in air
Old Jan 10, 2009 | 08:44 AM
topdog929's Avatar
I just received a code that said that there may be an issue with the catalyst converter. I have a 01 Maxima GLE and it has over 130,00o miles. Has anyone had a issue with their converter and if so, what was the resolution?
Old Jan 13, 2009 | 09:08 PM
well checked my intake and some other stuff.. erased the codes.. they came bak the next day, but then went away a lil later on... right now its not there.. but im sure the cel will come bak again
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
