i got a lowering situation
Old Jan 12, 2009 | 09:32 AM
spencer.justin's Avatar
tryin to max out the max
i bought my car used
2002 se
it is obvious that is is lowered
the springs are black
sitting next to any other 2002-2003 se it looks (but i have never actually taken any measurements) about 1.5 to 2 inches lower
just got new 18's with 40 series tires
the gap on the front is huge
i want to lower it more
but what springs do i choose
i want to lower it another 1 to 1.5 inches but dont know what springs are on it in the first place to know which ones i should change then out with
hhhmmmmm...?...?
Old Jan 12, 2009 | 09:51 AM
knight_yyz's Avatar
Toolie
the gap on the front isn't bigger. Nissan designed the front wheel well to be larger than the rear so it's an optical illusion
Old Jan 12, 2009 | 10:01 AM
Prophecy99's Avatar
first find out your true scenario before making any decisions,
dont forget you could get a bigger tire size to help out the huge gap instead of lowering.
my stock beefy 17" tires help a whole lot with the gap compared to my 18" low profile tires
Old Jan 12, 2009 | 10:23 AM
jeff5347's Avatar
what size tires are you running. ?/40/18
Old Jan 12, 2009 | 10:39 AM
Progress's Avatar
It's business time.
Larger wheels are compensated by tires with smaller sidewalls and vice versa. Going too big or too small may affect your speedo/odo.
Old Jan 12, 2009 | 11:04 AM
n3985's Avatar
大陆弟弟
Your solution is coilover, and FYI the *best* size 18" tires for us is 245/40/18 (as in speedo accuracy).
Old Jan 12, 2009 | 11:26 AM
IHAVEA2KMAXIMA's Avatar
COs ftw
Old Jan 12, 2009 | 11:43 AM
96max3189's Avatar
i think you got eibach springs they realy suck your best bid is tiens im telling you
look at my 96 only on 17" soo imagen you whit your 18" any more Q pm
Old Jan 12, 2009 | 11:50 AM
choiiiiiiiiiii's Avatar
wait, isn't this the fifth gen forum....
Old Jan 12, 2009 | 11:54 AM
the gap is larger than i want it to be, thats for sure
Old Jan 12, 2009 | 11:55 AM
235/40
Old Jan 12, 2009 | 11:56 AM
i am under the impress that most coilovers for the max's are noisy (make strange clanking noises), am i wrong, plus they cost alot more, and i would like to get illums when i change out the front springs
Old Jan 12, 2009 | 11:57 AM
eibach's are black?
Old Jan 12, 2009 | 12:53 PM
Puppetmaster's Avatar
[IMG]http://i40.tinypic.com/fc17he.jpg[/IMG
Eibachs suck? Please provide us some details.
Originally Posted by spencer.justin
eibach's are black?
Yes, and they should also say Eibach on them. The newer Progress springs are black too, but I don't know if they are labeled.
Eibach drop is 1.3" F and 1.0" R, while the Progress drop is 1.7" front and 1.5" rear. You could try measuring to see what your drop is like and use Housecor's site for reference.
http://www.shiftice.com/spring_strut_decision.html
Old Jan 12, 2009 | 04:23 PM
Yes and no. Coilovers are expensive, but -I- think they are worth it. Yes coilovers are "noisy" only if you get the cheap quality stuff. My D2 was making popping and clicking noise EVERY single time I turn my steering wheel. I thought it was because of the pillowball mount, but turned out to be my cheap rubber coil insultator got chewed up, so the coil was rubbing against the strut mount. I replaced it with a plastic ring and it made zero noise so far (knock on wood..). I would personally recommend you to stay away from D2 because of its poor "adjustable" dampening.
Old Jan 12, 2009 | 04:49 PM
irish44j's Avatar
retired moderator
The dumbness of this statement is simply amazing. Eibachs are widely recognized as one of the best performing springs for the Maxima. They have the correct rate and the correct ride qualities. More people here are on Eibachs than any other spring. Eibach is widely recognized as the leader worldwide in motorsports springs, and they make most of the springs for most coilovers that you can buy, as well...
you really don't know what you are talking about, as you have a 4th gen which uses DIFFERENT eibach springs than the 5th gen, with different rates and a lower drop.
And to suggest Teins
H-techs....too low a spring rate and bottom out
S-techs....simply one of the worst-performing springs available our cars.
Both are "looks" springs for people who just want to look pretty and don't care about performance at all.
Old Jan 12, 2009 | 04:51 PM
irish44j's Avatar
retired moderator
If you're going to slam your car 3" low, no matter what you use the ride will suck, you will have noise, and you will blow your struts. Even illuminas are not suggested for a drop more than about 1.5" or so...
Sounds like you don't care about anything except being slammed and having even wheel gap. If that's the case, just cut a coil off your springs and go bouncing down the road with all the other
Old Jan 12, 2009 | 04:53 PM
irish44j's Avatar
retired moderator
what is the tire WIDTH? Because "40 series" just means the sidewall is 40% of the width. So if your tires are 225/40s, they will be shorter than a 245/40....
Old Jan 12, 2009 | 05:03 PM
djfrestyl's Avatar
Suspension Yoda
Black springs? Eibach perhaps, in which case, keep them.
H&R is dark blue but they don't have that low of a drop.
The new progress springs are charcoal/silver, no?
Maybe you have cut OEM springs, in which case, ANYTHING you pick would be better.
Old Jan 12, 2009 | 05:20 PM
'02_EMILBUS's Avatar
Here you go Irish... lol
235/40
Most coilovers? Perhaps the cheap ones as previously stated. They definitely cost more but that's because they are better. You can adjust your height w/ coilovers as well.
I've got the TEIN SS coilovers and they are great. I'd recommend them if you care about the ride and handling; that is if you have the extra cash to spend on them....
Old Jan 13, 2009 | 03:41 PM
i have no idea where you got the idea that you know what i care about, i do care about ride and performace i just dont want 3 inches of wheel gap on the front on my car, 1.5 i can deal with, but not 3, thanks for your imput
Old Jan 13, 2009 | 03:43 PM
235 is the max i can put on these rims i think
Old Jan 13, 2009 | 03:44 PM
ill have to check those out (reviews), sounds like my best option at this point
Old Jan 13, 2009 | 03:45 PM
thanks for the info folks
Old Jan 13, 2009 | 04:58 PM
Weeble1's Avatar
The Whistle go WOOOOO
Just saw this thread... to be totally honest, I would either heat the springs to temp and make them smaller or cut them...
Old Jan 13, 2009 | 05:28 PM
pmohr's Avatar
No more Maximas...
Listen to him, he's got the quietest suspension evar
Old Jan 13, 2009 | 05:30 PM
Weeble1's Avatar
hahaha, shut up. I didn't put them on!
Old Jan 13, 2009 | 06:36 PM
pbn85's Avatar
yea I have tein SS coilovers. the ride is honestly SO comfy and the handling is so tight. By far the best mod I have on the car
Old Jan 14, 2009 | 08:52 AM
this sounds like crazy talk, wouldnt that really screw up the handling if i dont heat them both perfectly the same?
Old Jan 14, 2009 | 10:43 AM
pmohr's Avatar
No more Maximas...
If you seriously consider cutting coils or heating the springs, then you're just an idiot, and it doesn't matter what we recommend.
Old Jan 14, 2009 | 12:30 PM
well that one not be the first person that has come up with a dumb idea on this board, like the one guy that was creating an exhaust leak on as a mod, so i do not try not to judge how stupid or not people on this board are
Old Jan 14, 2009 | 01:00 PM
Weeble1's Avatar
man I said that as a complete joke. Paul knows this which is why he said what he said. PLEASE don't try that...
Old Jan 14, 2009 | 01:52 PM
rroderiques77's Avatar
Demodded and Forgotten
Old Jan 14, 2009 | 02:01 PM
2002 se
hhhmmmmm...?...?
hhhmmmmm..?...?
http://forums.maxima.org/advanced-su...ics-links.html
hhhmmmmm..?...?
http://eibach.com/cgi-bin/start.exe/eibach/index.html
MaxLvr21
Oct 17, 2015 12:11 PM
JonBlz
Oct 5, 2015 06:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Garrettz459
Sep 28, 2015 02:50 PM
