Umnitza Orion V2 Angel Eyes
Old Feb 12, 2009 | 01:41 PM
  #121
Greeneyes's Avatar
I got mine yesterday too... Are all 4 rings the same size? I thought a pair of them were supposed to be smaller diameter like the old CCFL ones were...
I did the Home Depot clear lens back when I installed my Umnitza DDE's they work out very well... Im going to do the same with my new Headlights. You're supposed to get those Malibu replacement lights.
Old Feb 12, 2009 | 01:59 PM
  #122
nissandrvr98's Avatar
ya know...i just realized...there wasn't ANYTHING SPECIAL in my box
What'd u use from home depot to 'clear' the lens. do they have something that we can cut to put in?
and yea..they're all the same size-supposedly the low beam one sits a bit inside the round housing.
Not sure yet tho-anyone done these (or umnitza chime in) and know for sure?
Old Feb 12, 2009 | 02:18 PM
  #123
Greeneyes's Avatar
OH YEAH!!! there was nothing special in my box either! except for the 3M Tape strips... is that the special gift?
Old Feb 12, 2009 | 02:23 PM
  #124
umnitza's Avatar
Former Sponsor
Sorry guys We were going to include some keychain LEDs, and we ran out.
Old Feb 12, 2009 | 02:27 PM
  #125
Greeneyes's Avatar
Yeah you cut out the middle of the Malibu Lens to the same size as the Orange lens in your headlight. The orange lens simply pops out and if you cut the clear lense out to the same size it just pops right in. Matches up pretty nicely to the prking light lense right above it.
Old Feb 13, 2009 | 05:22 AM
  #126
ICULookN's Avatar
I received mine yesterday. A led keychain was inside the box, really bright. Thanks Umnitza.
Old Feb 13, 2009 | 05:56 AM
  #127
Deckdout2's Avatar
Play with my balls
Hey! Where's my led keychains?
Old Feb 13, 2009 | 06:36 AM
  #128
geez....i didnt have any 3M tape either. im not loved
jk..i picked up some 60 second epoxy-it ought to hold 'em
Old Feb 13, 2009 | 06:42 AM
  #129
i just did a search but found nothing...is this something they carry in sheets, whats the deal with malibu lens. Sorry but the turn clearing is new to me and im just a little 'unclear' ahahaha
no seriously i only see like landscape and spot lighting
Old Feb 13, 2009 | 07:48 AM
  #130
Greeneyes's Avatar
Yup they are outdoor lights... Here these are exactly the ones you need https://www.smarthome-products.com/p...bs-2-pack.aspx
You'll just need to cut them.
Old Feb 13, 2009 | 08:44 AM
  #131
ZXTwnT300's Avatar
Just want to clarify how these install. You just place the tape on the high beam ones, then place on the outside? How does that work on the low beam ones if they go slightly inside?
Old Feb 13, 2009 | 08:55 AM
  #132
ICULookN's Avatar
I was curious about that also since there no instructions and the install is different from the Predator thinline instructions on the website.
Old Feb 13, 2009 | 09:32 AM
  #133
this is true-i plan on doin these this weekend
-Umnitza: whats the process you guys used for mounting the same sized rings?
Thanks!
Old Feb 13, 2009 | 04:41 PM
  #134
umnitza's Avatar
Former Sponsor
We usually use masking tape and glue, glue the rings in, hold for 30 seconds with masking tape, let dry, shake the light before re-install
Old Feb 16, 2009 | 07:00 AM
  #135
Installed on Sat-took about 3 1/2 hrs. only hiccups i had was shearing off the two bolts holding in the drivers headlight. heres some pics!
The hard part...
The payoff-camera does NO JUSTICE for these. im gonna try it with the wifeys (these were on my cell)
Old Feb 16, 2009 | 08:09 AM
  #136
ZXTwnT300's Avatar
How did you install them? Using the 3M stuff that came with them or what? What did you do for the low beam one (someone said that you have to put it slightly inside?)?Looks pretty sweet though!
Did you do any of the optional stuff and wire them to a switch inside?
Old Feb 16, 2009 | 11:16 AM
  #137
Ok, well mine did NOT come with 3M. I picked up some 60 second self mixing epoxy at home depot. The high beam is an absolute perfect fit but as we now know the low beam is tricky (a little). It kinda sits just inside the housing so i epoxied the two ends and the bottom middle then held it steady. There ended up being about a 1 mil gap around the ring (in some spots) so i just filled some of the space with a little more epoxy and voila.
For trigger wires i just used the included quick splices and tapped right into the parking light power on the headlight plug (red wire w/yellow stripe) I can take addl pics of the wiring if needed. So this way they are on whenever the park lights/headlights are one. Looks mean with just rings and fogs. It was a little chilly and i just wanted to be done so i said screw the switch (which was my original intention).
...and thanks,
I love em
Old Feb 16, 2009 | 02:08 PM
  #138
umnitza's Avatar
Former Sponsor
Were you honestly prepared for how bright these are?
Old Feb 16, 2009 | 02:26 PM
  #139
ill be honest..no
they are clearly visible from over 100 yards in direct sunlight...thats what 240 LED's will do i guess
-nice product
Old Feb 16, 2009 | 08:48 PM
  #140
ICULookN's Avatar
They look really nice. More pics of the wiring, especially in the back. Thanks.
Old Feb 17, 2009 | 08:55 AM
  #141
the red thread denotes the wire paths i used. Ill try to get some other pics this afternoon.
Old Feb 17, 2009 | 01:54 PM
  #142
More pics!
This is the tap into parking light power
heres the small circuit board inside the dustcap (you can see i highlighted the 4 connectors-its hard to see)
This is my relay and other wiring
Full Sunlight Daytime pic
Old Feb 18, 2009 | 09:09 AM
  #143
scottygill's Avatar
[IMG][/IMG]Has anyone done this install with the DataDot mounted HID's? Im interested but am timid to try to take apart the front of my car to get the headlights out w the extra mounting bracket. ShiftIce did not provide a install guide for this "uninstallable" lights. Is it obvious im still a newbie?
Old Feb 18, 2009 | 10:15 AM
  #144
ZXTwnT300's Avatar
I know I already thanked ya but wanted to thank you on here as well. Thanks for all the pics!!
Old Feb 18, 2009 | 10:22 AM
  #145
umnitza's Avatar
Former Sponsor
Old Feb 18, 2009 | 10:41 AM
  #146
assuming you meant me...no problem and good luck.
But we love you too umnitza
Old Feb 18, 2009 | 10:43 AM
  #147
newb doesnt mean anything..the willingness to try new things and LEARN is what makes you not a 'newb'
of course..there are exceptions
to answer ur question..i have no idea-no anti-theft kit here
Old Feb 18, 2009 | 10:46 AM
  #148
roggeezy's Avatar
Still can't get over the crappy fitment of the low beam.
Old Feb 18, 2009 | 10:48 PM
  #149
blkAEmax82's Avatar
Glory Glory Man United
Hey umnitza,
How much would it cost me for a set of these installed? (I'm local)
Thanks !
Old Feb 18, 2009 | 10:59 PM
  #150
umnitza's Avatar
Former Sponsor
Originally Posted by ae01maxine
Hey umnitza,
Thanks !
$200 for install.
Old Feb 18, 2009 | 11:03 PM
  #151
blkAEmax82's Avatar
$200 for install.
Is this Tim? I've talked to you over the phone once. Is this who I call about this deal, and how long will it last?
Old Feb 19, 2009 | 06:15 AM
  #152
read the last two pages...its been extended through february.
just make sure you mention its for the group deal through maxima.org
Old Feb 19, 2009 | 09:11 AM
  #153
blkAEmax82's Avatar
Did read the last two pages, that's why I was referring my question to Tim. Wasn't sure if that was a set deal or not since February is almost over.
Old Feb 23, 2009 | 07:04 PM
  #154
arcueda's Avatar
these fit 01 ae?
<- Stupid noob
Old Feb 23, 2009 | 07:08 PM
  #155
blkAEmax82's Avatar
Originally Posted by arcueda
these fit 01 ae?
<- Stupid noob
Negative sir, you would have to get 5.5 (02-03) headlights like the ones posted above.
Old Feb 23, 2009 | 07:20 PM
  #156
umnitza's Avatar
Former Sponsor
2002-2003 headlights only.
Old Feb 27, 2009 | 11:08 AM
  #157
SexiMaxSE's Avatar
Yeah the original pics that Umnitza had posted of that black Maxima.. thats my car. I originally had the Thinline Angels in my car.. Were great at first, but you notice that they are only noticeable AT NITE.. Plus the electrical connections were not solid enough and they were too easily detached from the halo itself.. What a headache.. The New V2s.. BLOW THE THINLINES OUT OF THE STADIUM. Damn near unbreakable (within reason) and ALL LED! I wouldnt waste your on the time with the Thinlines anymore. Go V2.. The way BMW drivers look at you when u roll up on them... OOHH So Worth It!!!! Umnitza takes great care of us here on the org. Very knowledgeable and always willing to help.
Old Feb 27, 2009 | 12:14 PM
  #158
Couldnt say it better.....BMdub owners have been eyeing these bad boys up like michael jackson at a pre-school.
I actually had a 4th gen owner at the turkey hill ask me what model it is...i told him 'built, not bought man'. then i referred him here-he hadnt heard of it-then i had to explain the internet as a series of tubes
Old Feb 27, 2009 | 12:32 PM
  #159
t-y1989's Avatar
so what was the final price on these...i need them...lol
Old Feb 27, 2009 | 01:09 PM
  #160
see their website at www.umnitza.com
they're $189 retail.
if you jump on this really quick they may hook you up with the GD price-tell em you're from maxima.org and cross yo fingers
