Cattman Y-pipe question
Old Nov 15, 2001 | 02:01 PM
acMAX's Avatar
for those of you who have a cattman Y-pipe.
I read the following on the Cattman website:
" The 3" Cattman Y-pipe requires a 3" catback exhaust system and is not designed to work with smaller diameter stock or aftermarket exhaust systems. Because there is no production 3" exhaust available, a custom solution is required. Customers are strongly advised to design the 3" custom exhaust from the 3" Y-pipe back to ensure proper fit and clearance."
So basically, they're saying you have to custom fit their Y-pipe onto your 5th gen max, right?
Is this the case for the Stillen Y-pipe as well? How much is the Stillen Y-pipe anyway?
Thanks guys
Old Nov 15, 2001 | 02:17 PM
theMax's Avatar
Re: Cattman Y-pipe question
Thanks guys
no custom fitting, the 3" is for the cat-back. It bolts up just fine to the manifold but you need 3" for the rest. This needs to be custom done. (3" bpipe and muffler)
Stillen does not make a 3" y pipe. The stillen pipe is about $350
Old Nov 15, 2001 | 02:28 PM
acMAX's Avatar
Re: Re: Cattman Y-pipe question
do you know what the difference is between the two y-pipes?
Old Nov 15, 2001 | 02:29 PM
HulaMAX's Avatar
Aren't the 3" Cattman y-pipe's only for those with an SC?...or can NEone use them too?
I wouldn't think so cuz there wouldn't be enough back pressure...
Old Nov 15, 2001 | 02:34 PM
Sonic's Avatar
The 3" Y's are for forced induction cars. While you can drive around with it NA, I would imagine that it would suck power away from you. The correct size for a 3.0L engine is 2.5".
Old Nov 15, 2001 | 02:35 PM
theMax's Avatar
3"
3" pipes are for boosted applications like SC or NOS. It would decrease HP in a NA car. Bigger is not always better. Best NA is between 2 and 2.5"
The stillen is cheaper because of the material it is made of. Cattman is stainless and won't rust as easily. There are varying opinions on the quality of each pipe dependin on who you ask. I just ordered a cattman.
Old Nov 15, 2001 | 02:59 PM
acMAX's Avatar
cattman
so Cattman also makes a 2.5" y-pipe as well I assume.....
Old Nov 15, 2001 | 03:00 PM
HulaMAX's Avatar
Re: cattman
Yup...the 2.5" y-pipe info is right above the 3" info. Check the site again.
Old Nov 15, 2001 | 05:51 PM
UMD_MaxSE's Avatar
Got Bent?
I would stick with 2.5" exhaust unless you are running a lot of boost....
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
