5.5 Gen Tokico Illumina's Settings
Old Jan 24, 2009 | 06:46 AM
fflint_18's Avatar
Hey Guys,
Only had my 02 for a few weeks. Last owner (also an Org member) had Illumina's installed. What settings does everyone use??
This is a daily driver that I want to handle well. Probably won't be doing anything like Autocrossing. Well as well as you can expoect a 4DSC.
I thought it felt kind of soft and when I looked today I noticed that the fronts were set at 1. Not sure what the rears are. Will check later.
I had them on my Integra and if I remember correctly I had them set to 2 or 3.
When I followed up on the Tokiko site I found that 1 is the softest setting.
The car has 90K on it with fairly new Michelin Pilots all around..
What settings does everyone normally use??
Thanks.
Old Jan 24, 2009 | 06:51 AM
scarface4522's Avatar
1 is the softest 5 is the stiffest ,jus change the settings, take it for a ride and see what setting u like the most. are u on stock springs? i have mine set at 3 in the front and 5 in the back
Old Jan 24, 2009 | 07:26 AM
fflint_18's Avatar
I'm assuming that they are stock springs. Definitely stock height.
First thing I have to do is look at the back.
Thanks for the info.
Old Jan 24, 2009 | 09:21 AM
knight_yyz's Avatar
Toolie
i like 3 front and 5 on the rear as well
Old Jan 24, 2009 | 09:43 AM
FlipCpt45's Avatar
i have illuminas with eibach springs
Is the rear suppose to feel really stiff @ 5? they don't seem blown.. i was expecting more stiffness.. i run 5/5 and i feel like its still not stiff.. lolz Is it better handling wise to not be at 5? maybe the eibachs isn't reaching its progressive rate.. hmm
All the car has is shocks, springs, and rims other than that its stock performance wise..
Old Jan 24, 2009 | 09:59 AM
maximadave's Avatar
detailerdaveb@gmail.com
It's a preference really depending on your springs. I have 3F/5R
Old Jan 24, 2009 | 10:32 AM
mist max2000's Avatar
wow i guess 3f 5r is the new 4f 5r ....ill have to give it a try...
Old Jan 24, 2009 | 10:45 AM
RA030726's Avatar
I'm nutty for Nissans
If your running stock springs leave them at 1. Other wise you have too much dampening and loose contact with the road over bumps. Its all about matching your compression and rebound with the spring rate.
Old Jan 24, 2009 | 11:07 AM
FlipCpt45's Avatar
hmmm, i think i like 3/5.. its weird that the rear feels tight, but the front feels actually more smooth throughout corners.. and i don't get the bumpy ride as much as when i had 5/5.. I didn't really mind the bumpy ride, as i was actually expecting and hoping for a stiff set up..
Old Jan 24, 2009 | 11:10 AM
fflint_18's Avatar
Thanks All,
I understand JSutter saying leave them at one to match spring rates, but it almosts feels like I'm not gettin any damping. Almost like it bottoms hard on small potholes.
My car seems like a twin to Mist MAX2000 but without all the goodies.
Tomorrow I'l bump it up a little and see how it seems. It's so easy I might as well give a couple different settings a try although everyone seems to be running much stiffer in the rears.
I'll let everyone know.
Thanks,
Bert
Old Jan 24, 2009 | 12:23 PM
Majestic Ken's Avatar
i ride 5f/3r. only because my rears are not blown but stuck on 3 i'll be doing coilovers in a couple weeks so its whatever
Old Jan 24, 2009 | 01:39 PM
PulsarGTS's Avatar
Im riding on 2/4 now. They front was just too stiff when it get very cold here, crash over bumps was rediculous at 3 or 4. But during the summer 4/4 was great and I may try 4/5 when spring hits. On eibachs btw.
Old Jan 24, 2009 | 05:03 PM
FlipCpt45's Avatar
Do you have any other suspension mods? ...Eibachs really? Your car looks WAY lower than my car..
What the heck is causing that crashing sound anyways?
Old Jan 24, 2009 | 06:39 PM
MIK3's Avatar
I'm running 3F/4R and liking how it feels thus far. I haven't had a chance to play with the damper settings yet.
Old Jan 24, 2009 | 07:27 PM
Puppetmaster's Avatar
I had mine with Progress springs and mostly had them on 3F/4R for regular commuting. On road trips I went to 2/3 to try to make it a little more comfy.
I did try 4/4 or 4/5 for fun, but those were much less forgiving on rough roads obviously.
The best thing about these is you can play around with them, so I'd say just experiment until you find something that suits your driving, your comfort preference, and road conditions.
Finkle
Sep 27, 2015 09:53 PM
homeyclaus
Sep 3, 2015 06:15 PM
95Maxi
35
Sep 2, 2015 10:37 AM
soloist3
29
Sep 1, 2015 03:47 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
