Odd intermittent noise from right vent
Old Jan 25, 2009 | 02:27 PM
Stormzusmc's Avatar
I've searched a little bit and found 4th gens that may have the same issue, but no resolution..
Anyway the issue is a odd squeaking noise from the vent (sounds to the right) whenever my heat or air is on. Now it happens pretty much when it wants to. Its a lower pitch squeak the shutters in and out. Its not the belts lol...and I really dont think its a mouse! Anyone see this recently?
Old Jan 25, 2009 | 04:11 PM
maximadudeIIs's Avatar
I had the same issue and it was the blower motor. After replacing the blower motor the noise was gone.
Old Jan 25, 2009 | 08:39 PM
Stormzusmc's Avatar
thanks sounds like a cheap fix
Old Jan 26, 2009 | 04:44 AM
AEMAXIMA01's Avatar
Depends on what you consider cheap. You'd be better off finding one from a junk yard.
Old Jan 26, 2009 | 06:47 AM
jasonmax's Avatar
whatever you do, don't lube it and put it back in.
Old Jan 26, 2009 | 08:31 AM
+1
I got a remanufactured one and it is still working to this day (4 years later) so most likely one from a junkyard will be fine too.
Old Jan 26, 2009 | 09:50 AM
Prophecy99's Avatar
has anyone figured out what makes thses things go? i suspected dirt and not changing the in cabin air filter.
Old Jan 26, 2009 | 09:52 AM
Stormzusmc's Avatar
touche salesman! i shall pick one up when i get back from tucson
Old Jul 24, 2009 | 10:04 PM
Solome's Avatar
I have a 03 with the same type of problems. Usually the blower will stop working on any level except the highest. I've replaced the blower motor - noise gone for 6 months. Then replaced the switches - noise gone for 2 months and now the resistor...and it started making the same noise 5 days later.
I'm stumped and frustrated.
Now I've got a really weird sound coming from (what sounds like) the front left wheel. In the morning (or anytime after significant tempature drop) it almost sounds like two balloons rubbing together. After two repair shops that I really trust nobody can find anything wrong with it. It's started making the sound while driving at highway speeds but closer to the center of the car.
Any ideas?
Old Jul 25, 2009 | 09:23 AM
foodmanry's Avatar
Da Roller Coaster!
Good question...probably a combination of dirt and a cheap bearing or poopy engineering on the blower.
Old Jul 25, 2009 | 10:36 AM
Stormzusmc's Avatar
the blower just sucks...my in cabin filter has been regularly changed...
Old Jul 27, 2009 | 08:08 PM
latinusmaximus's Avatar
Oh man! That noise has been driving me crazy. I'm in Phoenix where its like 900 degrees outside so I have to use the ac. I knew it had be something in there. Thanks! I was telling my friends it was the gerbils that were running in my engine lol
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
