Replaced Heater Blower Motor now airbag light flashes
Old Jan 28, 2009 | 07:20 AM
rosader's Avatar
I changed my heater blower motor last night which required me to take the glove box off and I had to undo some wires at the back to get it off. Well i put the new blower motor in and plugged the wires back together at the back of the glove box and put everything back together and the heater works great now but now the airbag light flashes??? I pulled everything back apart to see if i missed anything but everything is connected and looks fine. what did i do? how do i stop my airbag light from flashing?
Old Jan 28, 2009 | 07:29 AM
o0zarkawater2's Avatar
From what I remember from changing the In Cabin Air Filter, you werent supposed to unplug the airbag sensor (yellow plug), just slide it off where it was mounted on the back of the glove box.
I'm sure someone else can chime in on how to fix it.
Old Jan 28, 2009 | 07:59 AM
TallTom's Avatar
that's what must of happened. This may be the fix:
http://forums.maxima.org/6064393-post4.html
or this:
http://forums.maxima.org/6322743-post16.html
Old Jan 28, 2009 | 08:41 AM
Teddie18's Avatar
Once you disconnect any part of the SRS system while the car battery is connected and or the key is in the ACC position, a fault in the SRS system is identified requiring you to reset it.
Old Jan 28, 2009 | 08:46 AM
knight_yyz's Avatar
Toolie
anytime you unplug an air bag you need to have it reset.
Old Jan 28, 2009 | 09:09 AM
Maxgig's Avatar
You nailed it.
Old Jan 28, 2009 | 12:15 PM
rosader's Avatar
Thanks that fixed it
or this:
vingodine
45
May 21, 2016 12:46 PM
doobadoo
Aug 15, 2015 06:43 PM
Flores94
Aug 13, 2015 01:17 PM
kirkhilles
Aug 8, 2015 10:53 AM
silver_i35
Aug 3, 2015 11:20 PM
