burned out Xenon '02 SE headlight
I'm looking to replace a headlight, and I assume that the dealership will ream me. I just want OEM or something similar.
1. Do I need to replace both side so they will match?
2. Can someone recommend a brand (if similar to OEM and cheaper) or place to buy?
3. Is it easy to replace it myself?
- I know this sounds like info that is easy to search for, but I have been unable to find it (I assume HID is something different altogether, as much is written about them).
go to G/D section any of the HID kit deals and ask for 35W D2R bulbs, in 4300k, should be like $50 or something like that shipped. changing the headlight bulbs is as easy as changing a bulb in a house lamp
btw, DONT touch the glass of the bulb.
Buy them online though. When I bought my max I got home and realized that drivers side headlight was out ( along with all but one of the marker lights) I shopped around and some places wouldnt even carry them and the cheapest I found was $150 for one. Luckily, I *****ed enough and I had them all replaced for free...long live the internet
oh ok I was getting ready to say...ITS NO WAY IN HELL I WOULD HAVE DRIVEN THAT CAR OFF THE LOT WITH A DEAD HID BULB, lol
GOOD call on that one
To the OP: if you go with one of the vendors that sell aftermarket bulbs, you probably won't get the same quality as the OEM bulbs. Aftermarket D2R bulbs (even 4300k) have a little more color, but their visibility is poorer and the cutoff is unclear as compared to OEM bulbs. This is coming from my experience of trying 3 different pairs of aftermarket D2R 4300k bulbs. I ended up going with a pair of OEMs off of ebay for like $110 for the pair.
Thanks for all the good feed back! I was dreading a "just do a search newbie" response.
I just need the bulb. OEM sounds good to me.
I can't find any OEM on Ebay (One says EOM, but sounds like its not as it is 6000k D2R)item # 150323509521
Any thought on finding a true pair of EOM Xenon bulb replacement?
I think I've got it now
Is $88 for 2 OEM xenon shipped about right?
Part #85126
DR2, 4300k, 35W
It says for Nissan but doesn't specify the model.
http://cgi.ebay.com/ebaymotors/PHILI...ht_1674wt_1443
Part #85126
DR2, 4300k, 35W
Not sure on that auction, others would know better than me. I'd probably pick up a cheap set from the GB section and install them until you can find a good deal on OEM bulbs. Then when you do keep the others around for spares so you aren't forced into this situation again.
Part #85126
DR2, 4300k, 35W
Part #85126
DR2, 4300k, 35W
Anyone tried these? http://cgi.ebay.com/ebaymotors/D2R-H...QQcmdZViewItem
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Oct 25, 2015 02:47 PM
It's probably just the bulb, maybe even the ballast. I doubt its the actual headlight. If it's the bulb, all you need is 1 4300K D2R bulb and your set.
