h4 kit install
Old Feb 4, 2009 | 01:22 PM
ohitzme's Avatar
h4 kit install
Well i got a plug and play kit from operatic here on the org but i dont know where to mount my ballast? Does anybody have pics of where they mounted theres at? Its a 2000 maxima se btw.
Old Feb 4, 2009 | 01:37 PM
Progress's Avatar
It's business time.
No pic but I mounted my driver side ballast on the battery and I believe I mounted my passenger side on the washer fluid resevoir, but could be wrong about the latter.
It honestly doesn't matter as long as it's flat and clean. I'm pretty sure my ballasts lost their adhesion and fell off a while ago. I've had my kit in for nearly four years like that without any problems.
Old Feb 4, 2009 | 01:40 PM
ohitzme's Avatar
So if it is not secure 100% it still will work?
Like what i mean to say is if it moves around a little while i am driving it, its not going to harm it?
Old Feb 4, 2009 | 02:10 PM
ohitzme's Avatar
Also does anybody know what to do with the OEM rubber protector boot around the old light bulb? I cant get all the wires through it with it being water-tight. And if i dont use it the peice that came with the kit is it small?
Old Feb 4, 2009 | 09:23 PM
Progress's Avatar
It's business time.
Do what you can to prevent it from moving around. I'm saying that even if it isn't taped up perfectly, it should still work. But you don't want the things bouncing all over your engine bay.
Old Feb 4, 2009 | 09:25 PM
Progress's Avatar
It's business time.
I don't know what kit you have but you should be able to fit the wires through that rubber washer dealy. You should keep that on there as it will help prevent condensation in your housing.
Old Feb 4, 2009 | 09:31 PM
Mr. Blue Sky's Avatar
IB4glarecityigotstoppedbycopsandgotafixitticket
Old Feb 4, 2009 | 10:29 PM
OhOhMax's Avatar
H4 HID kits come with GLARE SHIELDS.
Old Feb 5, 2009 | 05:14 AM
Progress's Avatar
It's business time.
<---- Nearly four years installed and no tickets. I've been flashed by hicks in the country maybe 5 times max and that is without any glare shield.
Old Feb 5, 2009 | 07:31 AM
its laughable that you actually think that this really eliminates glare, and makes it so it doesn't glare in other people's eyes. Lets assume it does, you are still using HID in a sub par lighting system as H4 is, not to mention in order to get enough usable light to be worth it, you will probably have to aim the headlights higher. This would cause glare whether or not you have a "glare shield". I used this type of setup for a couple of days(literally 2 days, and it had a casper shield or "glare shield") before I decided to go the projector route, which uses housings DESIGNED for HID. if you want a bit more explanation, look here. and here I thought we were trying to differentiate ourselves from the honda crowd.
MaxLife17
Jun 27, 2019 01:37 PM
mpbclutch33
Sep 8, 2015 06:21 PM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
