Failed Fuel Door Actuator?
Old Feb 5, 2009 | 09:55 AM
gpmax's Avatar
Anyone ever replace one of these or have them fail? The fuel door got stuck and after getting it open I cannot determine if the fuel door actuator has packed it in or not. I checked the hinges and spring and they are ok.
Can anyone tell me when they hit the fuel door release button does the white plastic latch actually move/twist to release the door? When I push the fuel door release button I hear a click, but nothing appears to be moving in the latch, release assembly? I push the relase button 3-4 times and then the clicking stops...like it only works for 3-4 times? Dead Actuator?
Thanks for any help.
-G
Old Feb 6, 2009 | 07:12 AM
gpmax's Avatar
No one can go out to their car and see if the white latch mechanism moves when they push the release button?
Old Feb 6, 2009 | 07:31 AM
Progress's Avatar
It's business time.
I'm parked in a ramp and I'm at work so I can't go check. Also, how can you check if it moves if your hand is on the driver's door. My arms aren't that long. If no one responds by tonight, I'll let you know.
Have you tried searching?
http://forums.maxima.org/5th-generat...-sticking.html
Old Feb 6, 2009 | 08:14 AM
gpmax's Avatar
I did search...but the fuel door doesn't stick-it opens freely and closes, the actuator is not popping it open though. I need to know if/how that actuator (white hinge piece moves freely or not) to determine if I need mine replaced. Seems like a simple swap but Courtesy wants $100 for the actuator and I'd rather not spend that if its not bad.
Thanks for any help!
Old Feb 7, 2009 | 08:46 PM
Progress's Avatar
It's business time.
Yes. When you push the button the white thing jets into the body of the car.
Old Feb 7, 2009 | 11:09 PM
Derrick2k2SE's Avatar
You can open it from the trunk by pulling out the carpet panel and getting to it from inside. It's not a "release button" but it can be opened.
Old Feb 7, 2009 | 11:35 PM
03jmax's Avatar
had the same problem a week ago when installed my new interior, i went to go get gas and the button would just go in blank even tho i could here the clicking noise so i started messing with it till it open, try a flat head screwdriver while have someone press the button that should work, did for me now it works good again
Old Feb 8, 2009 | 08:02 AM
nsnrider's Avatar
the plastic tab goes into the actuator body assembly as mentioned above. Have someone press the release button on door while you look at the plastic tab with fuel door open, if it hasitates to go in, the solenoid might be dying and in need of replacement. Mine is currently shot on my max and I have to use my keys to open the fuel door which sucks, waiting till i get another one to replace mine.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
trsandrew
Apr 8, 2016 06:45 PM
