Obnoxious shake - advice?
Old Feb 12, 2009 | 11:48 AM
jeisai's Avatar
I'm reposting this from the "Noob Question Thread" since it hasn't elicited a response there, and will get more views out here. I've searched and searched and can't really find anything similar to my problem.
My 02 auto Max shakes above 50, with certain spots where it seems calm and then it picks up again - example: it's shaking like crazy at 70, but at 75 it calms down slightly, then ramping up to 80 it gets progressively worse again.
When I let off the gas and coast, it seems to be more severe - when it's under load, it still sucks, but isn't quite as bad.
The CV's have less than 15k on them, the tie rod ends are brand new, the rotors/pads are brand new, the struts/strut mounts/strut boots are all brand new, and the alignment has been done twice - both times by the same shop, but I'm not really convinced they did anything. I've had the tires balanced, bled the brakes, inspected everything I can myself, and I can't figure out the problem. I've tried the 6-12, 3-9'oclock shake to check the hub/bearings, but it seems as tight as ever.
The rear tires have mild cupping, but it's not bad. I plan on getting them replaced this weekend, along with my front right wheel hub/bearing.
The problem seems to be originating in the front right - for a while, it seemed as though, at highway speeds, when I veered left it would smooth out, then when I veered right it would shake again. However, I can't really tell for sure whether that's the case or not.
The problem only started around the time I did the brakes and/or tie rod ends (can't remember which for sure), but I also blew a strut two days later, and replaced those this weekend (two weeks later).
Any advice would be greaaaaaat.
Forgot to mention, the car pulls to the right, and I feel the shake through the steering wheel, pedals, and the car itself.
Old Feb 12, 2009 | 12:18 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
sounds like the wheel bearing, i had almost all the same problems. i could feel it through the floor board. I too did the 3 and 6 test and it didnt move. My mechanic had a stethoscope to listen to them. All in all i changed it and it sounds great now. good luck.
Old Feb 12, 2009 | 12:22 PM
hardincah's Avatar
To me it sounds like a blown strut - yes i read where you wrote you just replaced them. A blown strut usually shakes around 65+mph. Thats my only thought, because a bad bearing will shake always not just at certain speeds. I'm not a certified mechanic but thats usually my experiences in this case.
Maxima112 --give what he said a shot. It might fix the problem.
Old Feb 12, 2009 | 12:29 PM
jeisai's Avatar
It did this before and after I replaced the struts - and it doesn't make any other blown strut symptoms. I've had two struts blow before (my stocks got blown by crappy Vegas road construction), so I know what it feels like.
It does shake at pretty much all speeds, but it just shakes LESS at certain speeds.
And I will try his idea tomorrow afternoon (gotta wait for the paycheck) - I might as well do the wheel bearings on both sides if I'm going that route.
Thanks, guys. I appreciate the advice - this site has been a life saver over the past few years.
Old Feb 12, 2009 | 01:49 PM
98maxse5spd's Avatar
Swap your front wheels to the back. That could tell you if it's a wheel balance issue. It wouldn't be the first time someone paid for a balance and it was screwed up.
Old Feb 12, 2009 | 02:12 PM
maximase86's Avatar
I love lamp.
This might be a possibility, but you could potentially have a slightly bent rim. Rotating the wheels might move the problem around, but might at least help you find out if it's the wheels themselves or something else.
S
Old Feb 12, 2009 | 02:21 PM
S
Wheels or tires could do it. A tire can be significantly jacked up without looking bad. As long as the back wheels and tires aren't equally whacked then swapping with the fronts would expose a problem along these lines.
Old Feb 12, 2009 | 07:23 PM
jeisai's Avatar
I did this tonight, and it did something weird - the shaking stayed the same, but it pulls to the right now.
Can I set this one on fire and get a new one?
Old Feb 13, 2009 | 09:14 AM
njmaxseltd's Avatar
Possible tire issue.
Get a roadforce balance done, that will immediately flag a bad tire.
Old Feb 13, 2009 | 09:23 AM
jeisai's Avatar
What is the difference between a roadforce balance and a regular balance? Can I get it done anywhere (like Discount Tire?)
Old Feb 13, 2009 | 05:39 PM
CMax03's Avatar
Roadforce balnce will measure your wheel runout and balance the tires/wheels and find the best location for the tire on the wheel to minimize the amount of weights for the optimum balance! It's only one balancer out there to ask if they are equipped with it...The hunter 9600.
Old Feb 13, 2009 | 06:46 PM
P. Samson's Avatar
Axleshaft/wheel bearing locknut torqued to spec? Have you looked at/checked the RH driveshaft intermediate bearing?
Old Feb 13, 2009 | 07:28 PM
jeisai's Avatar
Had this done today, and no difference.
Unless it's backed off since the CV's were replaced, yeah it's torqued correctly.
I'll have to look at a picture to see what you're talking about with the intermediate bearing.
Just inspected the LCA bushings, and they're shot.
Old Feb 13, 2009 | 08:00 PM
P. Samson's Avatar
The fact that it seems to change with power on.......then coasting, makes it quite possible that it's related to the driveline. Unless you personally did it yourself, or witnessed the torquing (not just impacted) of the axle/bearing locknut/s, then I'd sure check it/them. It wouldn't be the first time these things have been found loose after front end work. You seem to have covered everything else. Just saw your LCA bushing comment. Have fun.
Old Feb 13, 2009 | 09:07 PM
maxion20's's Avatar
my 01 is doing the same thing and pulls to the right....everyone keeps telling me its my wheel bearing...does that sound right?actually thats how i found this site searching for answers lol....
Old Feb 13, 2009 | 11:52 PM
jeisai's Avatar
I did the axle locknuts myself.
Old Feb 14, 2009 | 02:15 AM
CMax03's Avatar
Common factor is the tires. They will pass the balance act but what you're experiencing are bad tire with broken belts The cupping and lumps/welps. Swap/rotate the rear wheels to front and front to the rear ....If the rears have no cupping. Your steering wheel is feeling like the wheels/tires are following every little longitudal crack and trying to pull the steering wheel from your hands. Don't feel bad this broke tire belt syndrome has whipped alot of a$$es, even those suspension specialist and tire guys.
Old Feb 14, 2009 | 02:04 PM
jeisai's Avatar
So I replaced the tires with the cupping, but haven't been able to replace the others yet. The vibration seemed a bit less when I got the roadforce balance done, when I drove on some actual smooth roads, however, it still exists. I will put the rear tires on front and see if it goes back to being awful again, and if so, it's the the rear tires (formerly front tires).
Old Feb 14, 2009 | 04:08 PM
Jeff03sixer's Avatar
mine does the same thing... gets worse when coasting, comes on at certain speeds. when i did my brakes, it got a lot worse. i have to assume unbalanced rotors
Old Feb 18, 2009 | 11:09 PM
ActofGod's Avatar
Hey I have this same problem, just picked up the car on Tuesday. The shaking starts at about 65mph and didn't go away up to 75mph (I drive in traffic all day, that was all I could do).
The shaking gets pretty rough, you can feel it right through the steering wheel. The car is completely docile around town at lower speeds, though.
Goin back to the dealer!
Old Feb 18, 2009 | 11:47 PM
CMax03's Avatar
Any vibration that starts around 60-75 mph is usually tire balance related....which could be a simple rebalance or could be tire with belt shift. Bent rims are felt at all speeds depending on the severity. Vibration only while braking, is usually brake related, especially common on you 11" 00-01 Maximas...one hard panic stop from 75 mph and the Good vibrations begin!
Mahmuth
Aug 16, 2024 08:23 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
