Replaced Spark Plugs... Idle Issues
Old Feb 17, 2009 | 07:35 PM
wyche89's Avatar
Alright, so I replaced my spark plugs today, now my idle is all messed up. It's really rough... you can hear the engine stumbling... and it dips down to 500-600 rpms when it warms up. I double and triple checked that all the vacuum lines and electrical connectors were re-connected the way they were. All the coils are plugged in tight. All the manifold bolts are tightened to spec, EXCEPT the stud/nut on the left side, which is tight, but not with a torque wrench, cause I was having some trouble with the stud staying tight while torquing it.
I also did the accelerator pedal released position learning procedure and the throttle valve closed position learning procedure. I attempted the idle air volume learning procedure (which seems to be the same as the ECU reset procedure) but that didn't work either. The engine revs smooth, but what's the deal with my idle?
Also, can I drive the car like this? I gotta go to work tomorrow...
Old Feb 17, 2009 | 07:56 PM
Ahmad_1290's Avatar
what kind of plugs did you use?
Old Feb 17, 2009 | 08:03 PM
AltiMaxima2000's Avatar
Might be the ignition coils.
I'm in the process of replacing mine, because of sputtering and iratic idling.
Old Feb 17, 2009 | 08:17 PM
wyche89's Avatar
i used NGK platinums.. torqued all the plugs to 20 ft-lbs.. i was having a misfire, and i did the pull test on all the coils and injectors before i replaced the plugs and they all checked out fine.. so i figured my misfire must be from the plugs.. i didnt have any idle issues before the spark plug replacement
Old Feb 17, 2009 | 11:16 PM
Revs2Hard's Avatar
BARF
Did you disconnect the battery when you changed them? The ECU might need to reset itself so try driving it around for a bit.
I just did mine two nights ago with NGK iridium IX's that are 2 steps colder and a smaller gap. When I started mine it would die at idle and if it stayed runing it would jump between 500-600 rpm. After I drove it around for a bit the computer reset and now everything is ok.
Old Feb 17, 2009 | 11:32 PM
Revs2Hard's Avatar
BARF
I just found this there is a TSB on it...
http://maxima.theowensfamily.com/tsb...=2000&tsb=none
Old Feb 18, 2009 | 05:55 AM
wyche89's Avatar
yeah, i did disconnect the battery.. my idle situation is rougher than usual at all times.. then after about a minute, it'll dip down betweek 500-600 rpms for a few seconds, then it'll go back up to nomral, but still be rough.. so you think the ECU just needs to be reset? i'll try disconnecting the positive terminal of the battery for a while.. i've read conflicting things about resetting the ECU by disconnecting the battery.. some say overnight, some say an hour.. will it hurt by leaving the positive terminal unhooked for too long?
Old Feb 18, 2009 | 08:00 AM
Scottwax's Avatar
That's Mr. Detail to you
After you disconnet the battery, turn on your headlights and step on the brake and hold it down a few seconds. That will give the same effect as leaving the battery disconnected for hours.
Old Feb 18, 2009 | 08:07 AM
bgod's Avatar
Check the gap on the spark plugs.
Old Feb 18, 2009 | 08:33 AM
wyche89's Avatar
with the key in the "on" position?
Old Feb 18, 2009 | 02:21 PM
Scottwax's Avatar
I don't think it matters.
Old Feb 18, 2009 | 03:06 PM
Ahmad_1290's Avatar
I thought the NGK plats come pre gaped ..right?
Old Feb 18, 2009 | 03:13 PM
max929's Avatar
Did u drop any of the plugs???
Old Feb 18, 2009 | 05:39 PM
wyche89's Avatar
it is my understanding that NGKs come pre-gapped.. and no, i didn't drop any of them.. i think i have a vacuum leak fellas.. i have the NWP IM spacers, and i didnt re-apply any RTV when i put the IM back on because i gotta rip it apart again friday or saturday to put on my valve covers.. i was told that would cause a vacuum leak, and thus.. the idle issues that i'm having
Old Feb 18, 2009 | 07:50 PM
tbergma1's Avatar
Well you didnt drop them but i have gotten plugs that were dropped by pepboys employees or at the factory. I always check the gap regardless. I'm **** like that and i can sleep at night. I always by one more than i need and keep in the garage. Just in case. I think you might have a vaccum leak with that spacer on.
Old Feb 18, 2009 | 08:50 PM
wyche89's Avatar
yeah, i no doubt do have a leak.. would that cause the idle issues though?
Old Feb 18, 2009 | 08:54 PM
tbergma1's Avatar
sho nuff
Old Feb 18, 2009 | 09:14 PM
Scottwax's Avatar
Absolutely.
Old Feb 18, 2009 | 10:39 PM
wyche89's Avatar
sho nuff
Absolutely.
cool.. i'll fix that this weekend then
I have one more question that I could really use some help with. I wasn't able to torque that nut on the side of the intake manifold down correctly because that stud in there kept coming loose when I torqued it. How do I get that stud down in there tightly? I tried the method where you put 2 nuts on there, hold the bottom one, then tighten the top one, but it got very difficult and felt like I was going to strip something if I kept trying. How do I tackle that stud?
Old Feb 18, 2009 | 10:55 PM
CMax03's Avatar
Use some Loctite 272 and a female torx bit if it's like the Oem stud!
Old Feb 19, 2009 | 06:26 AM
Auston's Avatar
Brake bleeding on 2000 Maxima and spark plug removal and installation
Old Feb 19, 2009 | 06:44 AM
wyche89's Avatar
well it's not an OEM stud, it's a stud that came with me NWP intake spacer kit.. i'm not sure, but i dont remember if there's a fitment for a female torx bit...
EDIT: by female torz bit, i'm assuming you mean a tool that allows the stud to penetrate it, and not a tool that does the penetrating into the stud? that would make sense because females ae usually the ones being penetrated.. lol
Old Feb 19, 2009 | 09:59 AM
tbergma1's Avatar
Loctite is your friend
Old Feb 19, 2009 | 12:07 PM
nissandrvr98's Avatar
dude....
Old Feb 20, 2009 | 01:56 PM
wyche89's Avatar
alright so basically, i could put some loctite 272 onto the stud to grip it, then use a female torx bit over the stud to screw it in like a normal bolt?
Old Feb 21, 2009 | 09:34 AM
realtor's Avatar
If the NGK's have the number 11 at the end, they are already pre-gaped.
http://www.ngksparkplugs.com/docs/te...tnumberkey.pdf
Old Feb 21, 2009 | 07:50 PM
wyche89's Avatar
ok, i put in the valve covers, RTV'd both of those and the manifold.. the idle is smooth now for the most part, but it still drops down to about 600 RPMS every now and then and gets a little rough.. i still have a small intake leak because i STILL couldn't get that damn IM stud in tight, and i think that's whats causing the leak.. i went around the corner to the auto parts store before hand, and they didnt have any locktite. i asked the dude if they had any tools to do that sort screw in a stud like that, and he said no.. so what i did was took some pliers, gripped the smooth part of the stud and tried to turn it that way.. i did get it down some, but the stud still loosened up when i tried to torque the nut onto it.. i think something in there got stripped because i saw little metal shavings on the stud when i took it out.. HOW DO I FIX THIS THING!!??!! lol.. kinda frustrated with this intake leak...
is it as simple as just drilling a new hole and putting a new stud in there?
Old Feb 21, 2009 | 09:33 PM
maxximaa's Avatar
mine's been idling at 700RPM forever since i got the car at normal operating temp.
should i be worried?
Old Feb 21, 2009 | 10:14 PM
wyche89's Avatar
look it up to be sure, but i think normal is 700-750.. you should be alright
Old Feb 21, 2009 | 10:47 PM
CMax03's Avatar
Maybe heli-coil time it sounds like it's possibly stripped!
Old Feb 22, 2009 | 08:21 AM
wyche89's Avatar
yeah, i've been reading about that heli-coil stuff.. is that hard to do and/or expensive? i'd like to do it myself if possible
PH98I30
19
Jun 13, 2016 02:38 PM
Maxboy23
Aug 21, 2015 11:02 AM
doobadoo
Aug 15, 2015 06:43 PM
Turbobink
Aug 15, 2015 07:20 AM
maxima297
Aug 3, 2015 12:50 PM
