5.5 gen fog lamp replacement
Old Feb 24, 2009 | 07:21 PM
Zack342's Avatar
So my drivers side fog lamp is cracked and needs to be replaced. I searched the forum for a how to but have been unsucessful in finding one. Can anyone tell me the best way to remove the fog lamp? Also does anyone have the part # for the Drivers for lamp and passenger fog lamp?
Old Feb 24, 2009 | 08:18 PM
scarface4522's Avatar
http://www.shiftice.com/piaa_fogs.html
Old Feb 24, 2009 | 08:23 PM
dlew329's Avatar
http://www.moodym.com/maxima/tech/foglight.html
Old Feb 24, 2009 | 08:24 PM
joemax2000's Avatar
I have a 5th gen but i assume its similar if not the same.
Take off splash guards on both sides of the car under each fog lamp.
Remove 1 screw on bottom of each fog lamp.
Tricky part**
Push metal spikes from fog lamp out of plastic clips on inside of bumper.
I did so by taking my headlights out and hitting the spikes through with a hammer while someone else tried to pull it out from the from.
Old Feb 24, 2009 | 08:32 PM
knight_yyz's Avatar
Toolie
for part number, http://forums.maxima.org/5th-generat...w.nissan4u.com
261505Y725 RH
261555y725 LH
Old Feb 24, 2009 | 08:42 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Remove the splash guards as mentioned (1-10mm screw, 1 phillips screw and a couple plastic clips)
Unhook the connector (small flat head screw driver works well for me)
Remove two (2) 10mm nuts from the two studs on the fog light housing (one directly above the other)
Pull out from the front of the bumper
Reverse order to re-install
Old Feb 24, 2009 | 08:45 PM
Zack342's Avatar
261505Y725 RH
261555y725 LH
pretty expensive!
261555y725 = $178.41
Old Feb 24, 2009 | 08:51 PM
knight_yyz's Avatar
Toolie
or buy ebay knockoffs
Old Feb 24, 2009 | 10:20 PM
ptviperz's Avatar
Originally Posted by Zack342
It looks like it might be cheaper for me to buy a whole new fog light kit than it would be just to buy the left fog lamp!
B61E0-5Y700 = $166.95
$66 each on ebay....they work fine.
Old Feb 24, 2009 | 10:40 PM
DoubleOmax's Avatar
i have an extra left fog lamp off my 5th gen. ill sell it to you. Don't know if its the same as the 5.5 gen though.
Old Feb 25, 2009 | 05:18 AM
Puppetmaster's Avatar
I found a used OEM fog light housing on eBay for 50 bucks. There's also www.car-part.com.
Also, those write-ups were all in the new Stickied How-To/DIY thread.
It's not.
Old Feb 26, 2009 | 09:28 PM
$EXY BLAXIMA's Avatar
while we're on the subject....... when you do a 00-01 to 02-03 front bumper conversion, when it comes to the foglights what do you actually have to change to make them compatible? are the harnesses different? (this is not a thread jack or anything, i just want to know while we're discussing foglights.)
Old Feb 27, 2009 | 08:05 AM
LA02MAX's Avatar
Just bought mine from courtesy nissan a couple weeks ago and got rid of the two holes that have been in my foglights for 3 years. So much better. They're pricey as hell though...I paid $175 or so
Old Feb 28, 2009 | 04:20 PM
reyrey's Avatar
pretty expensive!
Why not try calling Dave B. (South Point Nissan) and ask for a price. His pricing is very reasonable. If you don't like, then eBay is your option or used parts.
Old Mar 2, 2009 | 08:27 PM
maxximaa's Avatar
i took my headlights off when i did mine, i dont like sand falling in my eyes, neither wearing safety glasses.
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
MikesChevelle
Aug 19, 2015 07:19 AM
MaxStock
Aug 12, 2015 08:33 AM
MikesChevelle
Aug 6, 2015 11:36 AM
