Ball joint install
Old Feb 25, 2009 | 07:31 PM
Peanuthead's Avatar
Ball joint install
How hard is it to install the ball joint back into the control arm? I've done it before on my Sentra and it was very straight forward. I just took a 2-3 pound sledge and hammered it back in, stuck the snap ring on it and away I went. Anyone install them with the arm on the car? (Just asking for reference)
Old Feb 25, 2009 | 08:49 PM
knight_yyz's Avatar
Toolie
I used a press at work to push the maxima ones out. Not sure how easy it would be to hammer them out and new ones back in. But it's the same design, snap ring holds them in along with the press fit
Old Feb 25, 2009 | 09:36 PM
Love_00_Max's Avatar
It is quite an elaborate exercise (having done it on my maxima). You will need to rent the right tools like the press and snap ring pliers to get the snap ring in place after pressing the balljoint into the control arm. One useful tip on the web was to freeze the balljoint overnight before installation, this enables pressing a lot easier.
Old Feb 26, 2009 | 08:55 AM
blkAEmax82's Avatar
Glory Glory Man United
You could rent the tools at Auto Zone/Kragen etc, it wasn't to bad to do. GL with yours.
Old Mar 2, 2009 | 04:13 AM
bs02maxima's Avatar
yup had my 2k2 on jack stands in my driveway doing them..use moogs if you do replace them..and def. get the right tools dont use a hammer. you want to make sure the ball joint goes in as straight as possible into the lower control arm..i had to use a ball joint press basically a big c-clamp modified to hold/push the ball joint in..it wasnt any fun layin on the ground having to thread the ball joint press in to push the ball joint into the c/a but it worked..you will not like putting these in with a hammer/sledge..i suggest since your under there if you havent replaced the sway bar end links do so
Old Mar 2, 2009 | 08:22 PM
maxximaa's Avatar
ball joint? i think i replaced the whole shebang, not sure what it's called but it runs from the transmission(AT) to the CV joint bolt. was pretty easy. FSM got me stuck since it explains every single parts, I went to NAPA and bought the one that's plug and play. It's like the whole arm.
Old Mar 2, 2009 | 09:13 PM
pmohr's Avatar
No more Maximas...
Sounds like you're talking about the axle, which isn't related to the balljoint in any way.
The LCA is what people replace that come complete with bushings and balljoints. The LCA doesn't touch the trans, so you can't be talking about that...
Old Mar 4, 2009 | 08:00 AM
maxximaa's Avatar
its 39101 that i replaced.
Thats LCA?
Old Mar 4, 2009 | 08:04 AM
pmohr's Avatar
No more Maximas...
Thats LCA?
No, that's the axle, which has nothing to do with the balljoint.
Old Mar 4, 2009 | 03:46 PM
maxximaa's Avatar
k now im confused, wheres the balljoint? how about CV? what does CV stands for?
sorry im using the OP thread to learn some stuff
Old Mar 4, 2009 | 03:47 PM
Stormzusmc's Avatar
Constant Velocity Joints
Old Mar 4, 2009 | 03:52 PM
pmohr's Avatar
No more Maximas...
Indeed.
http://en.wikipedia.org/wiki/Constant-velocity_joint
The balljoint is the tip of the LCA, it allows the knuckle to spin around so you can steer and allows the LCA and knuckle to move up and down with suspension movement.
Old Mar 4, 2009 | 03:55 PM
blkAEmax82's Avatar
Here's what is looks like on Maxima LCAs. Its the bottom part of the picture with the nut and pin going threw it.
Old Mar 4, 2009 | 04:01 PM
nismology's Avatar
I've installed a new balljoint without removing the arm using a BFH.
AaronL
Nov 15, 2020 11:52 AM
MaxLife17
Jun 27, 2019 01:37 PM
2kmaximel
Sep 16, 2015 03:19 PM
Bonka
Sep 14, 2015 11:18 PM
Johnny9595
Sep 3, 2015 05:18 AM
