wheel spacers
Old Mar 2, 2009 | 06:17 AM
phxgold's Avatar
wheel spacers
I have 19x8.5 40mm offset wrapped in 235 35zr 19's dont know what size spacers I need for the rear. Its a tossup between 15mm-20mm at 20mm will I need to roll the fenders with an s tech drop? anyone with experience on this please chime in. TIA
Old Mar 2, 2009 | 07:32 AM
diverdown3's Avatar
Although I can't provide a response with experience at this point, I did go through the wheel & tire specs thread to see what contributors had run successfully. My conclusion was that a 19" x 8.5" wheel can safely range between 30mm - 45mm positive offset. You probably still have room for a conservative spacer.
I would suggest a search for the spacer terms you're looking for. "20mm" should work for starters. I think most results should pertain to wheel spacers.
The wheel and tire spec thread should help as well. Contributers specify if they used spacers and the size used.
Old Mar 2, 2009 | 10:57 AM
scarface4522's Avatar
go for the 20, i got 19 x 8.5 with a 35mm offset and i just put 15mm spacers for the rear and about to put 5mm in the front.
Old Mar 2, 2009 | 03:19 PM
PulsarGTS's Avatar
I wouldn't go over 15mm in the rear. Even with a recentered rear beam, 15mm spacers on 18x8 with a 35+ offset it rubs on the big dips. You should be fine with 15mm since you have alittle more strech to your tires than my 245s on an 8" rim.
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
