Tire Shopping
Old 03-02-2009, 11:15 AM
jspagna's Avatar
Tire Shopping
I have a 2003 Nissan Maxima Titanium Edition and need replacment tires. The car is stock,has the stock Titanium Edition wheels,not lowered or modified in any way. What is the biggest tire I can put on the 17 X 7 rims?
Is it a 235/50/17 or a 245/50/17. Thanks in advance for all the help.
jspagna is offline
Old 03-02-2009, 11:26 AM
Maxgig's Avatar
I don't know if they are the biggest you can use on stock rims but I have 350Z rims and I'm running on 245/45/17's with no issues. For my stock rims I have 245/50/17's.
Oh, and I forgot to mention that I have 3mm wheel spacers up front and 5mm's on the rear.
Maxgig is offline
Old 03-02-2009, 11:29 AM
SoulEater's Avatar
just stick with factory's specs.
SoulEater is offline
Old 03-02-2009, 11:48 AM
phatboislim's Avatar
i have 255/50/17s on my stockers
phatboislim is offline
Old 03-02-2009, 12:08 PM
jspagna's Avatar
Really? No clearance or rubbing issues? How does it look & handle?
jspagna is offline
Old 03-02-2009, 12:26 PM
it looks ok...handles...ok..they are michelin, so i wouldnt advise any road and track or autocross on it lol...
no rubbing..i think the car calls for that size...its on your door jam i believe.
Old 03-02-2009, 12:31 PM
diverdown3's Avatar
If tires are sized excessively oversize, they will underperform in comparison to factory spec'ed tire sizes. Of course, assuming all other factors are constant. I would reccomend staying within 1 increment over factory spec. Also there are several graphical tire size calculators out there on the web. Search within this forum and you shall find.
diverdown3 is offline
Old 03-02-2009, 12:38 PM
AEMAXIMA01's Avatar
The stock size is 225/50/17, not 255/50/17. There should be absolutely no issues w/ 225/50s but I cannot speak for 255/50s.
AEMAXIMA01 is offline
Old 03-02-2009, 12:42 PM
maybe it is 225/50s? lol
Old 03-02-2009, 12:53 PM
sublime258's Avatar
Why would you want to put a bigger size tire on a stock rim than factory spec? The ride might be a little softer, but they will look bad and your speedometer will be off.
sublime258 is offline
Old 03-02-2009, 01:10 PM
NissanTun3r's Avatar
you need to ask yourself, WTF am I thinking? And why shouldn't I stick with the stock specs?
NissanTun3r is offline
Old 03-02-2009, 01:50 PM
It's business time.
Progress's Avatar
First, wrong forum. Second, you do not need to run factory spec tires on stock wheels. I and a lot of other members run different dimension tires on stock wheels. 235/45-17, for example, works fine with stock wheels without offsetting speedo/odo.
Progress is offline
Old 03-02-2009, 02:08 PM
diverdown3's Avatar
Not trying to start an arguement by any means, but a 235/45/17 tire will result in speedometer error. When the speedometer reads 60mph, actual speed will be 58.7mph or 2.2% slower.
There is a 0.5" reduction in tire diameter for the 235/45/17 as compared to the 225/50/17 factory spec. tire.
Tippy Toes's Avatar
I would go with 235/45/17. Nice low profile look with some extra reinforcement.
As far as speedo goes, If you go 245/255 I think your speedo is off a few mph and possibly effects your miles.
When I had stocks I believe I went with 235/40/17 but that threw off the mileage.
Tippy Toes is offline
Old 03-02-2009, 02:15 PM
diverdown3's Avatar
Here is a great website for the information you need for your tire purchasing decision.
http://www.wheelsmaster.com/rt_specs.jsp
Old 03-02-2009, 03:16 PM
jspagna's Avatar
Wow, I didn't think this subject was going to raise so much smoke.
Well I don't want to go crazy with tire size, I just wanted a little more meat on the pavement.
So here is another question. Why is it that when I went to the Wheelmaster link, it told me a 17 x 7" rim can fit a tire size of 235/45/17.
But when I go to Tirerack, the same tire size says I need to have a wheel width range of 7.5-9"s? Which is correct?
The Tirerack site says I can go with a 235/50/17 for a 7" rim????
I hope what I said makes sense. So what do you guys think?
jspagna is offline
Old 03-02-2009, 03:21 PM
It's business time.
Progress's Avatar
Try finding good tires with the stock specs under $400 shipped. I'll take 2.1% error.
http://forums.maxima.org/908397-post71.html
http://www.1010tires.com/tiresfilter...s&tab=category
http://www.miata.net/garage/tirecalc.html
Progress is offline
Old 03-02-2009, 04:36 PM
jspagna's Avatar
This answered my question. I am going to go with the 235/50/17. It's a beefier tire and fills up the wheelwell and is not too low profile which is what I am looking for.
Thanks much.
jspagna is offline
Old 03-02-2009, 08:45 PM
PadawanKnight's Avatar
Thanks much.
stick with the stock size...no need to change unless you're going to buy new wheels
PadawanKnight is offline
Old 03-03-2009, 12:06 AM
V51V's Avatar
This site has always served me well, even gives you % you speedo will be off & in what direction. Also strongly advises against buying tires out of a nominal change in size, check it out if you havn't already... http://www.1010tires.com/TireSizeCal...?action=submit
V51V is offline
Old 03-03-2009, 04:49 AM
Tippy Toes's Avatar
That's a good link^^^^.
I have 20's and I'm 5.067% slower on the speedo(2.9 mph)
Old 03-03-2009, 06:32 AM
is invisible
CoolMax's Avatar
http://forums.maxima.org/tires-wheels-53/
CoolMax is offline
Old 03-03-2009, 09:06 AM
Puerto Rico-Maxima Lover
Lontar1's Avatar
keep the factory setup looks better that way
Lontar1 is offline
03-12-2020 12:06 AM
06-06-2017 02:01 PM
Bonka
09-14-2015 11:18 PM
Quick Reply: Tire Shopping
