Rear brake job... help
Old Mar 3, 2009 | 10:26 PM
NismoSpeed's Avatar
So i'm attempting a rear brake change, and have run into so many bad issues. Like not being able to compress the caliper. We finally took the whole thing off and screwed it down. So tell me what i'm doing wrong... Plus I got a brake set from Nissan and one set doesn't have a clip on it. Bad set or is it okay?
Old Mar 4, 2009 | 06:47 AM
njmaxseltd's Avatar
The caliper piston screws in clockwise. Don't just push it back or you will damage the caliper. Only one pad on each side has a wear indicator clip on it. I put that pad on the calipers piston side.
Old Mar 4, 2009 | 07:06 AM
phatboislim's Avatar
if its hard to push in..just replace teh caliper or u will be changing that soon..like me
Old Mar 4, 2009 | 07:50 AM
ReauDog's Avatar
The first time i ever changed my brakes on my max, i also didn't know you had to "screw" the piston back in. Every car i've ever had before this one you could "push" them back in using a C-clamp..... I almost killed myself trying to do that with these calipers.... lesson learned.
Old Mar 4, 2009 | 08:11 AM
maxximaa's Avatar
how do you screw it back in? i need to know coz im changing the rotors this weekend.
thanks
Old Mar 4, 2009 | 08:12 AM
MidtownNJ's Avatar
you will also need a special tool..unless you wanna muscle it with needle nose pliers..
Old Mar 4, 2009 | 08:14 AM
MidtownNJ's Avatar
need any help just PM..
Old Mar 4, 2009 | 08:29 AM
Ahmad_1290's Avatar
This thing will help a lot
you can rent it at autozone
Old Mar 4, 2009 | 08:34 AM
troof^
Old Mar 4, 2009 | 09:07 AM
fflint_18's Avatar
You can buy a small square brake wrench for a couple bucks. They usually sell them at Autozone with all the different specialty tools.
It's a cube that has 8 different sizes of nubs to fit many styles of calipers. It is made to go oin a 3/8 inch socket extension.
Find the right size to fit your caliper, hook it to a socket wrench and just turn it right in.
Way better than trying to use needle nose (which I've done many times)
Old Mar 4, 2009 | 10:19 AM
NismoSpeed's Avatar
We got them on, and it's loads better. Now one issue, the left rear has two lines around it on the rotor. They are just lines and not indention lines. Like it almost seems like you could scratch it off, but it doesn't. It doesn't squeak or make any noise. So i'm wondering if we just got grease from our hands on the pad. All in all, everything turned out good.
Old Mar 4, 2009 | 12:28 PM
ReauDog's Avatar
thanks
I just used a big set of locking pliers. Lock it on there, turn, unlock, reposition, lock, turn again.
mvm062
Nov 30, 2020 09:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
