Levoc Auto Shifter...
Greg's gotta new shifter...
Anyone installed one yet???
http://www.custommaxima.com/GroupDea...ShiftKnob.html
ADMAN
ADMAN
Re: Levoc Auto Shifter...
ADMAN
ADMAN
Dixit
Re: Re: Levoc Auto Shifter...
Originally posted by BigDogJonx
I believe Keving installed one of these. I remember asking him where he got it from.
Dixit
Dixit
Dixit
Dixit
I got the all chrome one. If you want pics ... check out my homepage. They are pretty sweet. The install was a pain, but glad I did it.
hmm... I have been thinking about getting one of these for the longest time... question is, what should i get.... carbon fiber or black? I have a blonde interior.... nothing else is carbon fiber though...
also... how tough is the install? Thanks!
Originally posted by sleepur
Is it me, or does it seem kind of tall? Seems like it rises a lot more in height than the stock auto shifter. At least that is what it looks like in the pics.
Originally posted by PCGuRu2K
The install was a @$@#$% to install.
ADMAN
Yeah, that's what I hear. I wrote Greg to ask if he knew if these were any better. Most people report that they needed to shave the white button and align the OD clip, etc. But, they act like it's a simple bolt on on mod. So...
ADMAN
ADMAN
It is not really height adjustable. There is a black plastic piece that needs to go into the top of the shifter in order to get it to shift/sit correctly. You can move it up and down on the on the actual shift rod, but there is only one place for it to screw into. The pain was splicing the wires. You have to cut the original wires as close to the shifter as possible and honestly that gives you about 1 inch of wire to work with. It is not really long enough for butt connectors, and therefore solder is required. That is where the pain is. Once connected, you just slide on the new shifter and screw it in. As for a bolt on mod, yes it is, but ... its the wiring that is so difficult. If you take your time it can be done in an hour. If you are a master solderer (I just made up a word
) then you can get it done in maybe 30-45.
Just test it before putting everything back together. You need to make sure all gears work, and that you can remove the keys. Also make sure it goes into park. If it does not then you need to more the shifter up or down on the shift rod. Plain as mudd right??
It may be about an inch taller than stock but that's it. It just looks tall in the pics.
) then you can get it done in maybe 30-45. Just test it before putting everything back together. You need to make sure all gears work, and that you can remove the keys. Also make sure it goes into park. If it does not then you need to more the shifter up or down on the shift rod. Plain as mudd right??
that price sucks! i got mine from alex at southwest auto works.. Email him at alex@southwestautoworks.com tell him adam sent you.. 75 is his normal price for these... And its kinda hard to put in.. the wires connecting the stock shifter to the od button are way too short.. i had to remove my entire center consol and put in longer wires...
Adam
Adam
AaronL
Aug 8, 2020 10:31 AM
hayne
Oct 5, 2015 11:53 AM
Maximeltman
Sep 28, 2015 07:19 PM
