100,000 Club
Old Mar 30, 2009 | 06:38 PM
maxdriver10's Avatar
100,000 Club
So i did a search and didnt come up with much and i was wondering if anyone could tell me what things i should be doing for a 100,000 mile tune up? Im at 99,750 miles at the moment ...i changed the oil less than 2,000 miles ago (mobil 1 full synthetic), changed all the spark plugs at 87,000 miles, and have been running 93 octane in it since i got it (at 86,500 miles). As usual your help is greatly appreciated.
Old Mar 30, 2009 | 07:10 PM
Maxgig's Avatar
Maxdriver10,
I looked in my handy dandy 03 svc & maint guide. If you've been doing your regular maintenance items every couple thousand miles. The guide calls for you to change the oil and filter and do the premium maintenance and the schedule 1 maintenance list. The schedule 1 list consists of: replacing the in-cabin filter, spark plugs and tire rotation.
It also says to inspect the trans fluid, axle and suspension parts, all brake components, cruise control system, drive shaft boots, belts, exhaust system, ball joints, manual trans fluid, steering gear and linkage. Btw, the mileage to do this according to the guide is at 101,250 miles.
Bottom line, give the car a thorough inspection under the hood and under the car. Treat it as if you were looking to it over as a car you wanted to buy.
Old Mar 30, 2009 | 07:14 PM
thanks...I have been keeing up with the maintenance....just not sure about the original owner....the car was in good condition when i bought it and besides a bad starter nothing major has gone wrong (well at the moment its in the shop cause it failed emissions and is getting checked out)...thanks for the reply...I'll give the guides a look over once i get my baby back tomorrow afternoon
Old Mar 30, 2009 | 07:38 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
At about 125k now...
Since about 60k it's been the same
Oil Change every 7500mi
Seafoam
Chevron Techron
AutoRx
Annually
Full detergent run through cooling system
Change tranny fluid (overkill, but whatev)
Aside from that everything has been a-ok (knocks on wood). The only thing to go wrong was the starter, but I might have done so prematurley. I also had to replace almost the entire exhaust throughout ownership due to rust, and just changed the shifter bushing (HIGHLY recommended). Normal ish as well (brakes, tires, belts), but whatever, that's coming with any car
This summer I will be:
Clutch replacement
Front suspension bushing changeout
VIAS inspection / repair
Throttle body clean
Rear seal PM
I intend on hitting the 250k mark so long as I don't run in to an IACV failure, BUUUUT, I'm hoping that never happens. She still runs strong, and knowing what I know now, I would have gotten the same car.
Old Mar 30, 2009 | 07:43 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
no major thingd to do as long as you keep the regular maintenance up. So far I have 167K and my girl still runs like a champ. Hopefully will run 100K more.... good luck
Old Mar 30, 2009 | 07:49 PM
anomaly117's Avatar
check your inner tierods and lower ball joints, i know mine arent doing well. both joints and both tierods are in need of replacement, which leads me to expect it to be a mileage thing
Old Mar 30, 2009 | 08:22 PM
Is you ride quality suffering? Cause my max seems to he taking bumps a little "rougher" than normal...although I would hardly say it was ever "smooth" haha but I expected that
Old Mar 30, 2009 | 08:38 PM
arcueda's Avatar
98,000
needs: coilpacks/struts
Old Mar 30, 2009 | 09:58 PM
wally9mm's Avatar
100K Miles
I am currently at 99,585 miles.
The only parts that were replaced were drive belts. MAF, one front rotor and axel boots.
Besides regular maintenance like synthetic oil changes, tires, air filters, in cabin filter, wipers, coolant flush, one brake pad replacement, one battery, one windshield, one headlight element, and the b pipe connector rusting through, the 2K max was relatively trouble free.
At this point, I am only concerned with the alternator life.
What kind of mileage can I expect?
I have the HD alternator that came with the cold weather package and upgraded electrical accessories (heated seats, mirrors, rear defroster, auto climate control, Bose w/sub, power passenger seat, fog lights). I hope it last another 50K because thats when I plan to trade her in for a new max.
The car still rides surprisingly tight and rattle free. I drive domestic cars at work and at less than 10,000 miles, and they don't hold up and ride as good as the Nissan.
Old Mar 31, 2009 | 04:48 AM
vball_max's Avatar
I'm at ~ 99,925.....I'll be hitting the 100k this week. My only plans really are to replace the belts, maybe PCV valve.....i went through the whole list in the maintenance manual and everything else has already been taken care of in the last 15k or so.
Old Mar 31, 2009 | 11:58 AM
so the dumbf***s at the garage its at decided that they all of a sudden need it another day despite assuring me it was "a one day job"....they said they think its a cat but that may or may not fix the problem....i wonder what im paying them for?
Old Apr 1, 2009 | 11:46 AM
00MAXI's Avatar
I'll be hitting 200k in a month. I'm at 198,678
Old Apr 1, 2009 | 11:50 AM
Portugue's Avatar
I'd inspect your exhaust too...my wife has 120k on hers and the flanges are in rough shape.
Old Apr 1, 2009 | 11:59 AM
Maximascorpio's Avatar
At 140K or so
My baby's running just perfect at 140K or so miles, I gave my previous 96SE to my cousin and I think it is at about 240K or so lol
Gotta love Maxima's
Old Apr 1, 2009 | 12:08 PM
vball_max's Avatar
I turned the 100k this morning!!! WOOT!!!
ok.....i know.....its really not that exciting considering i am expecting another 150k out of her.
Old Apr 1, 2009 | 04:48 PM
MONTE 01&97 SE's Avatar
I'm at 99,400 and he pulls stronger than ever......you will get that if you take care of her. I sold my old 89 bad weather Max to a co worker with 204,000, now it has 215,000 and still runs like a champ on the original motor!
Old Apr 1, 2009 | 06:07 PM
lol so i was a little harsh on the mechanics....they got me an OE Nissan Cat (yes its OE i crawled under the car and checked myself) and installed it for $494.74....will be turning 100,000 this weekend now that i have her back in action!!!
Old Apr 1, 2009 | 06:54 PM
GoPack's Avatar
Thanks Maxgig. I am almost at 100,000 also. I guess I better check all that too.
Old Apr 1, 2009 | 08:46 PM
kys02WHIP's Avatar
PLUGS!
Old Apr 2, 2009 | 02:15 PM
LA02MAX's Avatar
I just drove 2900 miles round trip last weekend so my car's up to 96k I don't want that 6th digit, damn it!
Old Apr 3, 2009 | 12:51 PM
Thorzdad's Avatar
We're about 1,500-2000 miles away from 300k.
Old Apr 22, 2009 | 12:35 PM
wally9mm's Avatar
100,000 Maintenance
Went over 100,000 miles this past weekend!
To celebrate, I changed the oil and filter( Mobil 1), air filter and spark plugs.
The electrodes on the plugs were worn down to nubs. Replaced with standard OE plugs.
Changing them out weren't as hard as I perceived. It took me an hour to swap them out. I guess that I should have changed them earlier, but Nissan says their good for 100K.
Gone is that slight hesitation starting out in first gear.
Looking to see how much of an increase in MPG there is.
I used to get around 25-27 combined. Last I calculated it was down to around 22-23 MPG using Mobil oxygenated 91 octane.
Old Apr 22, 2009 | 12:48 PM
papasuede's Avatar
Just give the biach a bath. or check here
http://www.nissanusa.com/owning/vehi...intenance.html
Old Apr 22, 2009 | 09:01 PM
Shadowes61's Avatar
Yep.. i hit 100k next week. 99100 now. Still running good..but fuel problems...stalls after fueling..my gf's brother who is a mechanic said its probobly vaporlock..wich i cant see considering its fuel injected..but who knows. Getting it looked at this week.
Old Apr 23, 2009 | 06:41 AM
NmexMAX's Avatar
dot dot dot ...
Now you officially will have a Certified Hooptie.
Old Apr 23, 2009 | 09:58 AM
Prophecy99's Avatar
108931k
did the works at 90k belts, fluids, plugs, filters (in cabin is a must)
Old Apr 23, 2009 | 10:11 AM
MAXXfiend09's Avatar
Im about around 132,000k runs like a beast tho
Old Apr 23, 2009 | 10:34 AM
danger300z's Avatar
crap I need to catch up to you guys Im at 74K
Old Apr 23, 2009 | 12:15 PM
Hit 100,000 Monday the 20th. It pulls stronger than ever!
knight_yyz
Nov 1, 2015 01:34 PM
Andy29
Sep 29, 2015 05:32 AM
