Rear Brakes
Rear Brakes
Today my brakes started grinding and it surprised me cause I just had them done last year. I pull over and its the drivers side rear that is down to the metal, but the passenger side rear still has tons of pad left as well as both fronts. I see that my drivers side rear rotor is all scored. What could have caused this. I am thinking maybe a bad caliper....
Yup....most likely caliper. You could try greasing the slide pins with caliper grease, etc. but most likely that would be a temporary fix. Also, check to make sure its not just the parking brake mechanism on the caliper. That can get stuck sometimes. Spray some WD-40 on it and work it back and forth a bit.
Abnormal inner pad wear = caliper
Abnormal outer pad wear = hardware
Also make sure the **** on the caliper piston lines up with the groove on the inner pad, otherwise you will get tapered/abnormal pad wear.
Yeah I figured it was the caliper. I never felt any drag on the car and no burning smell so I didn't know I had a problem. Looking at my rotor it looks like its gonna need to be replaced or hopefully they can cut it.
