Power Door locks stopped working
i have same issue, i tested all the fuses but they are good. Question do your sunvisor lights work? map light? Also try to use the remote when your car is running can you lock the car or unlock it?
look at all the 10amp fuses. this exact same thing happened to me and i though i was looking at the right fuses but i wasn't.. it didnt even look blown but when i replaced it everything went back to normal
(sorry i dont remember which one it was)
on driverside, under stearing column, open the little box, there will be a pwr door fuse.. take it out.. there will be a metal piece inside, that connects the 2 'teeth' of the fuse.. if its not connected inside, its bad - needs replacement.
in the same fuse box my shift lock fuse started to go then went, i lost some lights, doors, and keyfob use, as well as the ability to shift my car out of park!
simple fuse does more than it claims
A bad fuse doesn't always look like a bad fuse.
I have a 2000 Max
MAGIC!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
Everything RANDOMLY STARTED WORKING AGAIN!
There's gotta be a short somewhere that screws with it.
Here's what happened:
So I'm driving to work and it's 5am so I throw on the rear defroster. Well it doesn't turn on so I freak out and I'm like **** not only do the doors not work but now the rear defroster is out!?!!
So out of frustration I keep pressing the button and then the little light underneath the button lights up so I giggle then I try the power door locks for the hell of it and LOL it worked too!
Even the bloody key fob works again so I'm one happy ****
just so you guys know, if you cant shift out of park the fuse is in the engine bay (left side facing engine) it is the illumination fuse i believe.
if your door locks dont work, check the door lock relay and fuses in the engine bay, not under the drivers side dash.
My rear door behind the passenger won't open for nothing, inside or out but the window works. The switch above the handle in the inside moves how it should, lock and unlock but still the door doesn't open. any suggestions?
King_Ten_Ahead
09-30-2015 04:27 PM
shaunkey1
08-18-2015 10:09 PM
kjm900r
08-05-2015 07:14 AM
