2 alarms..
Old Apr 1, 2009 | 05:52 PM
BigOgre's Avatar
2 alarms..
So im thinking I have 2 different alarm systems on my car. I have the nissan alarm that locks and unlocks the doors and opens the trunk and has a panic button..
But I can also set the alarm by closing all the doors and using the key in the drivers door and turning it, it will lock the doors and the car will beep. On that note when the cars off the alarm will set when I use the lock button on the inside of the car. So I cant be in the car with the doors locked without having the alarm set, and then I use the unlock button it doesnt disarm the alarm system I will have to use the keyfob to unlock it again. It gets annoying because both the systems clash sometime and will set the car off and I will have to scramble to see if i can stop it from the keyfob or i have to put the fey in the door..
Thanks in advance.
Old Apr 1, 2009 | 06:11 PM
Progress's Avatar
It's business time.
You sit in the car. You lock the doors with auto door lock (on the door). You then unlock the doors with the same auto door lock and exit the vehicle and the alarm goes off? Is that what you're saying?
Old Apr 1, 2009 | 07:11 PM
BigOgre's Avatar
You are correct my friend.. I also have two of those little red dots.. one my the clock and one by the little *** that adjusts the brightness of the cockpit
Old Apr 2, 2009 | 05:23 PM
BigOgre's Avatar
/bump please
CHAZMAX
Apr 23, 2002 02:47 PM
