Caliper Question
Old Apr 6, 2009 | 06:30 AM
str8max's Avatar
Caliper Question
Well over the weekend I replaced my rotors and pads on the front of my 2k Maxima cause of the crappy studdering braking.
The brake job went well and no problem considering I have done this 1000 times over....... but this time afterward the brakes work great but it feels like a sticky caliper.
What is the best way to test to see if a caliper is sticking?
Old Apr 6, 2009 | 06:50 AM
kbjy11's Avatar
check for..
exessive heat after driving
uneven pad wear
jack the wheel up, and spin the wheel. It should spin somewhat freely. Compare it with the other front wheel.
Good luck.
Old Apr 6, 2009 | 06:54 AM
rroderiques77's Avatar
Demodded and Forgotten
By sticky, do you mean the vehicle pulls to one side upon braking?
If it does, the it's either the caliper hanging up or frozen guide pins. Make sure the pins are not seized and slide freely.
Old Apr 6, 2009 | 07:36 AM
str8max's Avatar
it does not pull or seem to get hot.... and everything seems to be free moving I did a through cleaning when i changed everything thing out. i will check for the wheel free spin. I have only put about 30 miles since the change.
Old Apr 6, 2009 | 08:41 AM
Then why does it feel like a "sticky" caliper?
Old Apr 6, 2009 | 09:10 AM
str8max's Avatar
maybe its just because the pads & rotors haven't broke-in yet.... paranoid i guess....lol
Old Apr 6, 2009 | 10:19 AM
Oh ok LOL
Please note that periodic brake noise is normal. Avoid panic stops during the the next 200 miles. Excessive heating or hard use when new may cause brake pad glazing, preventing proper brake-in.
Old Apr 6, 2009 | 01:37 PM
str8max's Avatar
well it just feels as if the car is struggling to take off almost like its pulling something..... I will wait the 200 and see what happens.
Old Apr 6, 2009 | 08:55 PM
adoll's Avatar
pad springs
This might be off the wall but I have been trying to find a photo or any thing that shows how to install the pad spings on a 1986 maxima rear calipers. Can you help? I have them on my 1970 240z.
CMax03's Avatar
You'll be resurfacing them within another 2 or 3 months! Those itty bitty 11.0" rotors are warpers by nature!
Apr 16, 2020 05:15 AM
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
