RSB installed thoughts & question
Old Apr 11, 2009 | 03:56 PM
durckelg's Avatar
I just installed a Progress RSB. As a lot have stated, it has made a huge difference. Based on the way it bolts to the beam and arms, is it technically a sway bar or is it a brace?
Old Apr 11, 2009 | 04:26 PM
mannetti21's Avatar
congrats on the new mod...just curious how difficult the install was? lift or jackstands used?
Old Apr 11, 2009 | 04:39 PM
durckelg's Avatar
I couldn't have been much easier; it only requires 8 easy to reach bolts. My 14.4 volt Makita impact driver helped a lot. I used jack stands, though I may have been able to do it with ramps.
Old Apr 11, 2009 | 05:13 PM
SteveB123's Avatar
"Seek and ye shall find. Knock and the door shall open. Ask and it shall be given and the love come a-trickling down."-Kingston Trio
http://www.progressauto.com/ecom/download/62.1520.pdf
Old Apr 11, 2009 | 07:10 PM
Scottwax's Avatar
That's Mr. Detail to you
Technically, it is an anti-roll or anti-sway bar.
Old Apr 11, 2009 | 07:25 PM
Stormzusmc's Avatar
didnt you notice the anti part of the body sway the rsb produce for you? that would tell you what scottwax just said lol
Old Apr 11, 2009 | 08:51 PM
Progress's Avatar
It's business time.
Install is easy. It can be done with ramps as well.
Old Apr 11, 2009 | 09:26 PM
FlipCpt45's Avatar
Where do you put the jackstands? Under the axle / rear bar thing? Then bolt on the RSB?
So.. you jack up the car from each side of that bar and put jack stands on each side?
Old Apr 11, 2009 | 09:52 PM
mannetti21's Avatar
I can't remember where exactly I read this, but somehwere/somebody said that the sway bar shouldn't be installed with tension removed from the rear suspension. Therefore, it should be installed using ramps....any truth behind this???
Old Apr 12, 2009 | 07:39 AM
Progress's Avatar
It's business time.
Similar to LTB install. You can install with tension removed and then torque (the U-bolts) to spec once tension is back.
Old Apr 12, 2009 | 07:43 AM
Progress's Avatar
It's business time.
Jack stands should be at the jack points, you can't put them under the axle since the RSB will be under it.
http://www.vqpower.com/v2/articles.php?article_id=116
Old Apr 12, 2009 | 08:16 AM
wyche89's Avatar
That's probably what I need to do... My rear suspension is making a squeaking noise every time I go over a bump. Anybody else have this?
Old Apr 12, 2009 | 10:59 AM
diverdown3's Avatar
Which is why I made these.....
http://forums.maxima.org/5th-generat...d-adapter.html
Old Apr 13, 2009 | 09:50 AM
daredevil514's Avatar
If only I can find a RSB here in Montreal that priced decent.
Old Apr 13, 2009 | 09:53 AM
Progress's Avatar
It's business time.
Squeaking after RSB install? Check the bushings on the sway bar. I believe the install kit came with a non-sqeak tape or something that is wrapped around the bar. Maybe you need some of that.
Old Apr 13, 2009 | 11:13 AM
diverdown3's Avatar
My Progress RSB came with grease for the RSB\urethane bushing interface.
Old Apr 13, 2009 | 11:25 AM
Progress's Avatar
It's business time.
Yeah, maybe it was grease. It was so damn long ago!
Old Apr 13, 2009 | 11:36 AM
diverdown3's Avatar
And maybe they changed somewhere between yours and mine. I purchased mine from Cattman last December. I think the Progress manufature date was the prior month or two. I remember it was not old stock.
Old Apr 13, 2009 | 11:46 AM
sublime258's Avatar
I bought mine from Cattman last summer, and it came with grease. It was a relatively easy installation and is probably the most effective mod I have done to my car other than new struts/springs.
Finkle
Sep 27, 2015 09:53 PM
wingnut2006
Aug 15, 2015 04:16 PM
MikesChevelle
Aug 10, 2015 11:21 AM
MikesChevelle
Aug 6, 2015 11:36 AM
