ATTN: Y2KevSE & Yo_its_ok need your feed back on this product.....
Old Nov 20, 2001 | 12:15 PM
PRINCE NISMO
Sup fellas, I came across this information and I was wondering if you guys have heard of this upgrade and do you think it will show any real HP gains on a 5th gen? Thanks.
The Venom400 performance control module is an add on control unit that features it's own micro-controller. This module is connected to the throttle position sensor and the Manifold absolute pressure sensor, and by monitoring the sensors output characteristics and modifying the input signal to the vehicles existing ECU.
Dimensions: W 4.5" x H 1.25 x D 4.75"
Poison:
Improving horsepower by as much as 25% through the range of approximately 1,000 - 5,000 RPM. The Venom 400 is OBD II compatible. Besides substantial increase of torque, the Venom 400 reduces the flat spots or delay timing during sudden accelerations. Incorporated into the Venom 400 is an 8-bit micro-controller that is capable of monitoring the various sensor inputs and modifying their outputs at more than 40 times per second.
If you already have another performance prom installed not to worry the venom400 is a mid range performance chip and the prom chip is a wide-open throttle application thus complementing each other through the entire RPM band.
The Venom400 has an on/off switch so smog certification is possible without detection of unit. Easy installation with basic hand tools requiring only four electrical connections.
Old Nov 21, 2001 | 08:00 PM
max'n out's Avatar
HMMm ive heard about this...I can't remember what the exact things that where said where...but i think it was negative.
Old Nov 21, 2001 | 09:17 PM
Shadow's Avatar
It's expensive junk. Basically it manipulates your throttle into opening more. Just step on the gas harder. It gives no peak horsepower and no horsepower to speak of.
Old Nov 21, 2001 | 09:46 PM
PhatGuy
Damn cheaters!
Old Nov 21, 2001 | 11:31 PM
ToYLeT902's Avatar
JET Speed Lab
Old Nov 21, 2001 | 11:42 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Sorry, I'm not a nitrous guy so I can't really help you out. Do you have a supercharger question?
Old Nov 22, 2001 | 07:37 AM
UMD_MaxSE's Avatar
Got Bent?
I thought the Venom Nitrous kit didn't work on our cars
Old Nov 22, 2001 | 10:14 AM
ToYLeT902's Avatar
JET Speed Lab
Old Nov 22, 2001 | 11:18 AM
imccasli's Avatar
its not a nitrous kit, its an engine management system, and its is, as was said earlier, expensive junk....it actually robs power, even while turned "off", if still plugged in....its a complete waste of money....do not buy it
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
dcam0326
Sep 7, 2015 07:26 AM
Courtneysnow
Sep 4, 2015 05:10 PM
crazyespn
Sep 3, 2015 01:30 PM
