Sound Proofing
Old Apr 15, 2009 | 09:06 AM
tmuscedere's Avatar
Sound Proofing
My weekend project of sound proofing the doors is coming up and I have a few questions. Has anyone tried putting the sound proofing on the back of the door skin? If so, how did that work out? Where is the best spot to put the sound proofing on?
thanks for the help
Old Apr 15, 2009 | 09:20 AM
Progress's Avatar
It's business time.
Have you tried searching?
Do a search for sound deadening. Here are a few results.
http://forums.maxima.org/audio-elect...ng-thread.html
http://forums.maxima.org/5th-generat...-deadener.html
http://forums.maxima.org/5th-generat...y-new-max.html
http://forums.maxima.org/5th-generat...any-rolls.html
http://forums.maxima.org/5th-generat...deadening.html
Old Apr 15, 2009 | 09:32 AM
tmuscedere's Avatar
Links
Alot of dead links, after I had searched
Old Apr 15, 2009 | 09:54 AM
Prophecy99's Avatar
check out this great howto from housecor
http://www.shiftice.com/bose_deck_fix.html
Old Apr 15, 2009 | 10:13 AM
tmuscedere's Avatar
Doors
Mostly interested in best way to do doors. Can I do the back of the door skin? Or is it better to remove the moisture shield and sound proof the doors themselves. Or, can I put the sound deadener over the moisture shield. Dont know if that method would work to well though.
Old Apr 15, 2009 | 10:25 AM
n3985's Avatar
大陆弟弟
I have sound deadener directly on the skin, removed the moisture skin and another layer on the door frame plus another layer of acoustic sound proofer. Unless you have a system and running massive power to the door speakers, I say it's not really worth it. The doors close with a nice thud now, and the OEM speakers have more mid range and low thump, but all in all not that significant.
Old Apr 15, 2009 | 11:17 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
You'll want to use a closed-cell sound deadener; mats such as dynamant will only serve to minimally reduce in-cabin noise.
Old Apr 15, 2009 | 11:31 AM
Progress's Avatar
It's business time.
How about as to method? The question is should the door skin be removed and the sound deadener (whichever is chosen for the particular application) be applied directly the door, or can it go over everything?
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
