exhaust rattle!!!!!
Old Apr 20, 2009 | 08:31 PM
maxima dude's Avatar
exhaust rattle!!!!!
i got this rattle thats so loud and horrible sounding...my max has 50k on it...it sounds lik its coming inside right before the main cat...any1 have idea? idk wut it is. i jacked up the car and everything and held the heat shields and everything else...it only rattles when deaccelertaing...any help? thanx
Old Apr 20, 2009 | 08:37 PM
a33i30's Avatar
Are you sure it's not the heat shield, couse it sounds like it.
Old Apr 20, 2009 | 08:54 PM
^^ nope held every heatshield and didnt go away...its literally has to be inside...but my flex pipe on the ypipe is shot and ima relace it with a cattman ypipe one day but i held down the flexpipe with a crow bar and it still didnt go away at all....i just want it to be gone for now untill i save to do my exhaust
Old Apr 20, 2009 | 09:29 PM
a33i30's Avatar
Are your exhaust hangers okay? They might be stretched out/loose, allowing the pipe to hit the underbody.
Old Apr 20, 2009 | 09:42 PM
Ahmad_1290's Avatar
I had a nasty rattle. It was the rear precat. So i just gutted them both
Old Apr 20, 2009 | 10:12 PM
a33i30's Avatar
^That just might be it. Take it to an exhaust shop and see what they have to say.
Old Apr 21, 2009 | 06:23 PM
do you think if i gutt out the main cat(hopefully solve the problem) will is make the car raspy with a catback...im thinkin its jus lik a test pipe?
Old Apr 21, 2009 | 06:27 PM
hi-tek22's Avatar
my heat shields rattled at one point but that was near the main cat.....
Old Apr 21, 2009 | 06:29 PM
Its most likely 1 of the pre-cats. It might be that flex section as well. An exhaust shop can take care of both of those problems for you.
Old Apr 21, 2009 | 10:52 PM
sublime258's Avatar
I have a nasty rattle too, has been driving me nuts for thousands of miles. It only happens when the car is in drive and between 2000-3000 RPMs. Took it to the dealership and they blamed it on my broken flex pipe (which I know is not the problem). I am on the order list for a Cattman y-pipe, which should be coming within the next week. I am hoping to figure out what the issue is whenever the y-pipe gets replaced. It sounds like it's coming from the back of my engine though, can't really tell if it's coming from the y-pipe area or not. It's impossible to hear the noise when the car is parked, so I am pretty stumped. Will be taking it to an exhaust shop if replacing the y-pipe doesn't eliminate the noise...
Old Apr 22, 2009 | 08:57 AM
^^ yeppp exactly...i cant find it either
Old Apr 22, 2009 | 12:31 PM
02_Maxima_6sd's Avatar
50k miles? If it is the CAT, can't the dealer replace it free of charge under 8/80 warranty? I mention this because my pre-CAT bank1 gave out @ 94k and the dealer stated if under 8/80 it would have been covered.
user 11122324
42
Jul 18, 2022 03:35 PM
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
