hack job amp install
Old May 3, 2009 | 08:44 PM
anomaly117's Avatar
anyone know if its possible to splice power and remote to an aftermarket amplifier from the stock bose sub/amp assembly?
Old May 3, 2009 | 08:59 PM
AEMAXIMA01's Avatar
Might want to ask this in the audio/electronics section. You'll probably get more insightful information quicker than you would here.
Old May 3, 2009 | 11:06 PM
hotstartup's Avatar
doubt it, wont be enough power ull probably fry the harness. you want atleast 8 gauge wiring to run aftermarket subs.
Old May 4, 2009 | 04:39 AM
zero2sixtyZ's Avatar
You embarrass me.
Not sure on remote, but you definitely want to run a fresh line of wire for power as the draw will most likely be larger.
Old May 4, 2009 | 06:39 AM
bigpopaj369's Avatar
YES! you need one of these! http://www.dealercostcaraudio.com/stingersgn13.aspx u can get them at ur local best buy. as for the install u splice into the pos and neg leads and wire them in 2 pos wires into the sub pos and 2 neg into the neg sub and then for the remote wire u exposethe wires leading to the bose amp and splice the bright green wire with a thin white stripe down the side. obv u need to run a 12v cable from the battery to the new amp (im sure u already knew this)
Old May 4, 2009 | 06:44 AM
djfrestyl's Avatar
Suspension Yoda
Uh, no. Please disregard everything ^^ said, I can't even make sense of it.
You need a fresh power line. Everything else CAN be tapped at the HU, and you don't need an LOC. Do it right.
Old May 4, 2009 | 06:50 AM
apparently i misunderstood what he ment by power? and alot of shops install these when u keep bose everything. i wrote he obv needed a 12v cable from the battery?
Old May 4, 2009 | 06:52 AM
djfrestyl's Avatar
Suspension Yoda
You don't even need the LOC. It's giving you a line level signal, just splice in some RCA's. Do it at the HU so you don't have to do double work when you replace your HU.
This question would have been properly answered if the OP had read the stickies in the audio section, it's discussed ad-nauseum.
MaxLife17
Jun 27, 2019 01:37 PM
boomerbrian
Sep 4, 2015 08:25 AM
Johnny9595
Sep 3, 2015 05:18 AM
